Hairspring attachment
TimFitz
Hi
I have a Waltham model1883 Special size 18 15 jewel pocket watch I'm working on at the moment. The roller jewel is missing so I just started to take it apart to fit one , when I noticed the hairspring wasn't connected to the collet that connects it to the balance staff. The collet is there just not attached to the spring.
I haven't dealt with this before and would like to know is it possible to connect the spring to the collet again & if so how. Or do I need a new hairspring?
Thanks for any help
The hair spring is usually pinned to the collet in much the same way as it is to the stud at the other end so it's perfectly possible (if somewhat fiddly) to re-attach it. Whether or not it's a good idea depends on why it has become detached in the first place.
If it has simply become in-pinned then there should be no problem. You will need a brass taper pin, fine tweezers, a very steady hand, and the means of removing the excess taper pin once it is in place.
If on the other hand the hair spring has broken at the collet then there are two major issues to resolve.
1. You have to remove the existing taper pin and the broken end of the spring from the collet. very fiddly and you might be better off with a new collet.
2. The old hair spring is now too short. You will need to reshape the inner coil to fit the collet, and then add weight to the balance to bring the timing back into spec. You will probably need to reshape the outer coil as well to bring it back into alignment with the regulator.
Fiddle but not impossible.
I have been reading the Raul Horology blog with interest from the beginning lessons at his watchmaker school .
Attached is lesson 1 of assembling a hairspring to a collet and stud .
As Marc has pointed out , it is a fiddley endeavor .
http://raulhorology.com/2012/10/the-mark-of-a-true-watchmaker-forming-hairsprings-part-1-pinning-flattening-centering-2/
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
