Hello from Ottawa, Canada
MilTimeCan
On 9/3/2016 at 4:24 PM, Khronos said:
Welcome!  Yes, I so agree about Mark's videos!  What a guy!  I thirst to be able to run a pair of tweezers like he does.  It's so much fun to see a master craftsman work.  Beautiful!
oh, yes. sooo true.
I am in absolute awe with the ease which he moves watch parts around, it's like watching a ballet.
    • Hi I got a Jaeger LeCoultre K911 movement, where one of the stems was broken. Part no. Should be 401.  Im based in Europe and tried Cousins but its discontinued there and cant find it on Google. Is there a way out to join the ends? Or an alternative movement to source parts from?
