Omega cal 503 part needed
Just came back from total restore and wanted to make a small adjustment but when opened I found the screw cut off with no slot . So I need a new part. It's been a year restoring it and I don't really want to send it back to the guy for like the fifth time. He's two months before he even looks at things. Here an image of it now and before ! See the difference! Help
Richard
410-336-6490
That's a shame... For what it's worth I never use the swan neck adjuster - I just move the regulator itself. It's a friction fit, which allows the watch to be adjusted while leaving the pointer centred so it looks nice for the customer :-)
So although your watch man has bodged your watch, you can still adjust it, albeit with more care...
I looked up the part number you need and the image shows the screw already in place? So it's possible by ordering the spring that maybe the screw comes with but the screw is also available as a separate part. Then fortunately this part goes back to the base caliber 500 and looks like the interchange with basically most of the 500 series.
Then if your watch is fast by 6 seconds I wouldn't worry about it Omega has a specification for this watch anywhere from -1 to +21 seconds per day average in three positions over 24 hours.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Omega_503
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
