Any timegrapher do Accutrons?
Alastair
On 8/16/2016 at 0:48 PM, praezis said:
Many Timing Machines with paper strip from that time can test tuning fork watches.
I use a software based version that also can test them. You may have a look at this:
PC_Timing_Machine_info_eng_V2.pdf
Regards,
Frank
So interesting timing machine software. I notice it comments about a free version but doesn't say where you can get that? So zero website for the company anywhere?
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
