Saw this today and right now bid is at ~$30 USD, I searched and found some interesting results, from a company that just supplied watches for "tourist" trade with low quality movements to a real high end chrono movements, Venus and the like. I know it's not a popular U.S. brand, but would it be worth putting a reasonable bid on? This looks like a world timer, judging by the bezel.
What about the 4R36 grail-du-jour? Why putting the other watches in danger for a three-crowned stranger? All that because of a demode' Albionic nostalgia from a rebel land? Watch-out (pun intended), you could be listed in an auction soon if crossing the line.
I've seen the old Landeron based chronographs that were sold as Britix but nothing quite like this.  What do the pushers at 2:00 and 4:00 do on this one? As a tinkerer, the most important factor when considering a purchase for me is the type and condition of the movement inside.
I wish I knew more about function and movement, but it's one of those 'as is' type deals. It is like the 'box of chocolates' theory. Appreciate the comment, I don't like buying something I don't know about either.
Pretty safe on the 4R, not really a grail, (to me) supply is still plentiful, it's the price that is attractive. Self described cheap ba$tard that I am!!!!!
Thanks for your brutally honest input.
34 minutes ago, jdm said:
By the way, which day is "Date"? The day when they run out of proper dials? :D
good catch, probably one of those tourist models
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
