Montine 25 jewel automatic
Hi everyone hope you knowledgeable people can help me?
My late father bought me this watch in the mid 70's, montine 25 jewel automatic swiss made. The glass and strap have been renewed and it's never been serviced.
The watch keeps great time and all the functions are working, feels great on the wrist.
Any information would be appreciated.
Nigel
Hi Nigel, probably from the late 70s/early 80s right? Nice watch, the 25jewels on the watch lead me to think that it is powered by an ETA2452 or maybe 2836... a higher jeweled version which makes this a better quality watch.
Another clue to the watch's quality is that it seems to be made of steel (as opposed to plated metal) and 'incabloc' which is a type of shock-protection for the balance jewels.
Is that the original band? It would be nice to see it and also the back of the watch.
Since the watch is probably hitting 30years, it would be worthwhile getting it serviced. The original oils would have dried up and the metal parts are probably running dry. A service would see it right for the next 10 years or so if stored sensibly.
Finally, the value of this watch is in the memory of your father..that is one thing money can never buy.
Enjoy the watch and the memories!
Anil
Anil
Hi Anil
Thanks for the reply and advice, the watch is over 40 yrs old. I got it 75/76.
I'll post more photos when I get chance,
Strap is not original.
Nige
Anil
Hi Anil
As I don't wear the watch on a regular basis, and don't want to throw a lot of money at the watch.
would it be possible to just have the watch re- oiled ?
thanks for any input.
Nigel.
6 minutes ago, Shedinn said:
As I don't wear the watch on a regular basis, and don't want to throw a lot of money at the watch.would it be possible to just have the watch re- oiled ?
"Re-oiled" is the same as "serviced" because unlike car engines, watches need to be taken completely apart to be lubricated.
That cost from 100 to 400 dollars, euros, or pounds approximately. No need to do that if the watch is not to be used everyday.
Yes it would be possible, but not really a good idea.
If there is any dirt in the movement you will end up with what could be described as a very fine grinding paste that may end up causing rapid wear to pivots.
There is another reason and I found this out the hard way.  If there is any hard dried up oil in the jewels, fresh oil can soften it and cause it to expand.  This results in the pivots being gripped by the expanding hard oil and a stopped movement.
To expand and add on what Geo said. Physically one can "add oil" without taking apart the movement only to the upper and lower balance jewels, plus perhaps to one or two less important ones. Time to uncased the movement, remove hands, dial and redo is at least 30 minutes. Complete service can be done in less than 2 hours by an experienced watchmaker. Not much difference, not worth going for the shortcut, and no serious professional should offer that.
all valid points above.
When it comes to cost, you get what you pay for and generally good work does not come cheap.
However there are a lot of people who think that they can 'service' a watch but their work is poor (but not cheap!).
How do you know which one is good as even the worst butcher can hide behind the facade of a big modern shop.? The only way is by word of mouth recommendation from a neutral party.
If we know where you are located someone here could probably recommend a shop near to you or maybe tell you whom to avoid!
Anil
Anil
Thanks Anil
And everyone else for your input, I'll try and source out a local reputable shop and get a quote. I live in Castleford west Yorkshire UK if anyone can make a recommendation.
Nigel
    • I existed before the term mechatronics engineer existed. I had to combine electricity, electronics, pneumatics, hydraulics and computing just to keep my own equipment working. I have never sub contracted any of my own repairs to the suppliers because I know I could do a better job. For a long time, dental suppliers in my country would bring their dead equipment to me that their own engineers cannot handle. I have accidentally embarrassed a couple of hospital heads of engineering by demonstrating their inadequacy.  I think mechatronics is the most under-appreciated, under valued of all the engineering sciences. I had a part-time dental assistant about 25 years ago, who was studying mechatronics in the polytechnic. She was absolutely clueless about the job prospects for a mechatronics engineer. I asked her about her aspirations and she replied that she really wanted to work in the games industry.  In our dental profession, equipment have evolved from simple mechanical to electro-mechanical to logic-driven electro-mechanical and currently to computer driven machines.  The medical equipment suppliers who employ mechanical engineers and/or mechanical engineers cannot cope with the repairs of the newer equipment. And many times end up changing whole modules and whole machines just because they cannot repair them. But I think HR is afraid to employ a mechatronics engineer just because they don't know what a mechatronics engineer does. Mechatronics is much more fun. It combines almost all of the engineering sciences and produces an all-rounded engineer. But until HR changes their mindset, not all door will be open.
    • Welcome Tarheel, there is a lot of help on this forum...
    • Hello and welcome to the forum.    Enjoy
    • I can't find anything similar either.  All the writing on the case was a form of advertising, stem set, Swiss lever etc usually found on older watches.
