Eterna Matic ETA 2824 Original Yoke ?
Ive got a rather nice Eterna Matic 2002 in for restoration with an original ETA 2824 movement ( high finish ), only issue is the Yoke ( Part #435 ) is snapped and i can not source another from anywhere :(
Ive got the technical documents but im still a bit unsure about interchangability, so my question is.......
Can i use 2824-1/2824-2 yoke ( or all keyless parts ) in place of the broken parts ? ( given the design is different )
Simply put is it possible to update the keyless works to say 2824-2 ? Im hopeful but if not i will be forced to cry man tears :(
Any chance you could post a pick of the yoke as I think I have one in my spares. Ive got plenty from 2824-2 etc but just scraped a few older models with older keyless. if i have one you can have it with pleasure.
Edited by DJT2
spelling
Thanks for the responses guys ( and your generous offer DJT ), i rather stupidly forgot to check my ETA cabinet for spares :unsure:. ( shakes head in disbelief )
Turned out i had one of the older yokes all along in a 2836 service tray, silly of me to presume i didn't have one and not check.
Got me in quite a panic ( ohhhhh noooooooooooo kinda panic  ), but shes all good and ready for finishing , new glass is gonna be a pain to find to fit that inner bezel, but in the mean time i will seek out a new skinny strap.
Lesson of the day, CHECK your stock first and do not presume lol
MrBeat
26 minutes ago, jdm said:
Looks clean as the day the factory booted it out the door. I'd say, put a classy strap and ready for listing :)
Oh yeah the movement is now spotless not a scratch or mark in sight. A Hirsh strap is on order and im hoping one of the acrylics im going to be ordering will be a good fit with that inner bezel ( the original has a chunk missing :( )
Timings pretty good too +- 8 seconds, but the stem set & winding now works which is the main thing :thumbsu:
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
