Omega 1342 troubleshooting guidance?
PWR
I have a nice looking Omega 1342 Quartz that is not functioning with new battery.
I am wondering if there is any troubleshooting guidance someone can provide to figure out what might be wrong.
I am sure all the parts are in the watch.....
Appreciate any help.
Steve
I had one recently. This is what I did-
New batt, not running. Used Voltmeter on the points that attach to stepper-motor. Look for first a neg then a pos reading--every second. An Analogue meter is preferred to see the pointer swing, but a fast operating (Not Autoranging, as they are just too damned slow!) digital will do.
In my case, the pulses were present and the motor was O/C. New ones can be had from Sweden, but at a stupid cost...
Its part-number is-- 1342 9400, motor.
Just thought--The pulses Must be neg/pos alternating for the motor to turn forward each second. If one half of the 'H' Bridge of four transistors Inside the driver/timer chip are faulty, you'll only get pulses of one sign and not alternating, if this is the case, the chip/board/electronics will need replacement. This is a pretty early genuine Omega calibre and not an ETA Re-badge like they did later on.
It dates from the mid-late 70's, parts are hard to come by and expensive it seems. Omega do apparently offer re-built stepper-motors--To their dealers only--who will charge £400 to repair the watch, which these days prob isnt worth £100 unless sentimental...
If I was to have pursued this repair myself, I would have considered changing the entire movement for a nice quality recent manufactured one--but which cal, I didn't investigate, as the owner didn't want to spend lots on it..
I noticed in one of Johns pdf,s there is a re-set mode that increases the voltage but could not see how this is done. If  you can re-set It might be worth a try as it will free the movement up if is just in need of a service. I am not that familiar with quartz apart from a service requirement, it seems to be either the coil or stepper motors that fail. It is rarely the circuit that is at fault.
A book worth purchasing if available is "Repairing Quartz Watches" by Henry B. Fried
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
