On 7/29/2016 at 5:33 PM, Cad101 said:
Mine I got for under £40 I had alot of work to do cleaning it up but it was a bargain you can find them if you look around enough.20160526_001829.jpg
How did you manage to get the stakes so bright?
I ultrasonic cleaned them a few at a time to get rid of crud and dirt then put each one in a hand held drill and cleaned them with very fine grit wet and dry paper then each one with wire wool. The punch ends  which had a flat polished surface I left I only polished the shafts . Took me about a week to do the whole lot.
Just received my K&D staking set from EBAY its not to pretty now , but using the great ideas for everyone here, I have started to clean everything up.It is not missing any parts & I'm pleased.
The cleaning is going well however two of the holes in the die plate are plugged, with balance staff parts I would imagine. I bought a cheap set or tiny drill bits that instantly broke.
Any good suggestions on how to unclog these?
Again thank you all for the advice on buying and cleaning ,I wouldn't have got it correct without your help.
I took before pictures and will post them with the after pictures when done.
On 8/21/2016 at 9:47 PM, tomcolson said:
I started out using only abrasives to clean up the stakes as described here. Currently (today in fact!) I start with an overnight soak in EvapoRust to remove most of the rust and convert what's left to black iron oxide. Then I use fine 3M radial bristle disks to polish up the working and marked ends. I take great care with the working ends to insure that I do not round over corners, etc. Usually the highly polished working ends are the least rusted parts of the stakes.
Awesome page! I enjoyed reading it.
1 hour ago, tmac1956 said:
All:
This is probably the best reference that I've found for the Inverto tool series. You can get either the hard cover or paperback reprint from lulu.com
http://www.lulu.com/shop/archie-perkins/the-watchmakers-staking-tool/hardcover/product-22409846.html
I hope this will help someone as much as it did me.
Tom
I'll second this recommendation...the clearest descriptions I've found of how to perform many useful task using a staking set.
The book also contains a reprint of a 1986 K&D catalog, but if that's all you need you can download it for free from kanddinverto.weebly.com.
Here is the after photo waiting for the dome
48 minutes ago, Don said:
Awesome! Great job.
Sent from my XT1064 using Tapatalk
The plating and paint were both falling off so the rust cleaning removed the rest. Perhaps black enamel would be nice? what do you think?
You could go full-on JG Hall and do black enamel and gold accents/borders :-).
21 minutes ago, TimFitz said:
I have to know, Whats JG Hall?
Inventor of the staking tool in the mid 19th century when, if it was worth making, it was worth decorating. His early tools were black enameled and decorated with bands of gold decorative motifs (Greek key and the like).
Thanks, I thought it was something like that
I'm partial to the light green that some of the old Star and Boley sets are painted. But black enamel would look very nice too.
5 hours ago, TimFitz said:
Here is my finished $45.00 K&D staking set all cleaned up & the new glass dome arrived today. All finished.
Now back to watch repairing.
The only thing I'm missing is the centering punch, I have tried all the usual places recommended from all the websites. I will eventually I'll find one. If anyone knows where I can pick one up please let me know. Thanks
Very stylish indeed. :thumbsu: The dome adds a nice touch and the overall package just screams old time watch maker. Keep an eye on uncle larrys site as he has stakes come up all the time. Looks like many years of use left in the old girl yet. As far as paint goes have a look into getting it powder coated, way nicer shine and super hard. We used to have our hydraulic jacks done and it would amaze me how many home projects came back with the shop work lol
Dave's Watch Parts has a  Marshall centering stake. Not sure if it will fit,  but worth a shot.
http://www.daveswatchparts.com/StakingTools.html
40 minutes ago, Cad101 said:
That's a nice set now it looks shiny and new. It's amazing what a little hard work can achieve well done.:thumbsu:
Thanks, I remember you said in a post, to keep looking & one would turn up. You were correct. $40.00 for tool $13.00 for very thick glass dome. Thanks for your help.
PS. hard to believe the before and after pictures?
Yes I saw that one,not sure if it will fit either. Thanks
Standard size for staking tools is 4.7mm. If yours are this size one from another ordinary set will probably (no guarantee obviously) fit.
Stephen
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
