Have a Seiko 9139 that wont really make it to the middle. There i a half second wrong. It bugs me Have tried to bend it but it gets back in the same position again. If i can hold it still i would work i guess? But how should i hold the tail and the pivot area still som i can bend the long second a little. Under control.
What part of the hand are you trying to bend ? Are you talking about when the hand zeros to 12:00 ? and it is 11:59 1/2 ? Pictures speak volumes. Thanks
The proper way to fix this is:
1. Remove the second hand
2. Run the chronograph.
3. Stop the chrono
4. Press the chrono reset - this will zero the mechanism by striking the hammer against the chrono wheel heart piece
5. Support the chrono wheel pivot on an appropriate tool - either a special holder for the movement or something like a bergeon 5409
6. While firmly depressing the reset lever, install the second hand exactly at 12:00 and press firmly in place
Holding the reset lever will keep the chrono wheel locked at 12:00 enabling you to get the alignment perfect. It is critical to support the pivot/jewel else you are likely to dislodge the jewel.
3. Stop the chrono
Have a holder for supporting the jewel so that is not any problem. The second has a fixed point where it sits at the pivot. I just wanted to bend the second a little to the left making it more straight.
58 minutes ago, sstakoff said:
I have also used a seitz jeweling anvil with appropriate pusher as a platform to support the jewel/pivot
Have a tool for the job of supporting the jewels . Have to remove the oscillating weight but that is no big deal.
I will keep it as is at least for now?
Have you checked to see whether or not you can rotate the heart piece on the pivot? Unless the second hand is actually bent incorrectly I wouldn't want to bend it. Doesn't seem like the correct repair.
On Seiko 6139 you can't rotate anything. But i will figure something out? Have some ideas i will test.  Like having two supports and laying the hand on the side and pressing a little in the middle?
Took an old second hand from a wall clock and overdid it? This is how my second looks but in smaller size. I would like to bend it back. If it's possible?
Get two very small diameter nails and hammer them very closely together into a block of wood leaving about three millimetres sticking out.  Place the second hand face down between them.  Now starting at the tip end of the hand between the nails, gently push or pull the hand to ease out the bends slowly working your way to the centre tube.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
