Seiko hands?
Stripped this down for a friend today and the centre of the second hand has pulled out, the collet on the centre of it has been tightened before and is and is a bit of a mess.
The second hand needs replacing, I rang seiko and it's a 6 week back order for the part.
I dont normally work on seiko Watch's so am not sure where else to try to source one faster than seiko UK can supply it and didn't really want to wait 6 weeks.
I wondered if anyone could suggest anywhere in the UK I might get a white second hand exactly the same as this one in the picture!
I have sent him a message on eBay, thanks.
Doesn't look like cousins have one, although I hate using their website off a phone and might of just not found one  but thanks for the suggestion.
3AX125FEASB or  3AX125FEASM
Even if from a popular model is not guaranteed at all you can find it easily. Try asking Dagaz or Yobokies if they have one left from mods.
Or place a replacement hand and have him come back when you have it.
Edited by jdm
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
