Tool for straightening pivots?
rogart63
35 minutes ago, Cad101 said:
hello Seitz do a pivot straightener I think I remember seeing one while surfing one day and nearly having a heart attack at the price.
That would be no surprise? Seitz shall have a look? Exactly but this was obsolete at cousinsuk.https://www.cousinsuk.com/product/balance-staff-pivot-straightening-tool
Edited by rogart63
  • Sad 1
12 minutes ago, szbalogh said:
Is it heresy to straighten in its own hole?
In my book, nothing is heresy as long as it works and doesn't screw things up more! If the plan is good....go for it! I've never done it so let us know how you fared!
Cheers,
Bob
I don't think you would get a perfectly straight pivot by using its own jewel to straighten it because of the hole tolerance. As I could see the pivot straightener uses progressively smaller jewel holes to straighten the pivot. Using the movement hole you would still have a slight bend which would bind with the jewel and cause friction which would affect your amplitude. But then again I may be wrong.
Cheers,
Bob
Did it with the Roskopf's escape wheel pinion. It is not jeweled just a hole in the brass plate. Now its barely visible and running great but You are right, its not perfect. And i think that there is maybe a chance that in a jeweled hole it can crack the jewel?
I was thinking this may happen too. There is always the pivot sizing tool I suppose, those that don't have jewels...would they work?
2 hours ago, ramrod said:
what pivot are you straightening? what movement?
Haven't got any pivot right now that needs to be straighten. I saw a great blogg by a Swedish watchmaker and he used a tool for straighten a balance. Looked so cool i had to find out more about the tool.
ah. got it. the reason i asked is that i won an auction on fleabay about a month ago and it is all parts - stems, some crowns and 95% pivots. tons of them. i couldn't use them in a lifetime. i'll give them away for anyone that needs them.
  • 3 years later...
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
