Non Smooth Setting
So this has been an issue that has cropped up numerous times. When I've reassembled a vintage watch, setting the time is very "jumpy", it doesn't want to turn smoothly. I've used D5 on the inside of the canon pinion, and the outside as well. I'm sure a seasoned watchmaker will know what this is right away.
Thanks!
Thanks!
And the movement is?
32 minutes ago, frenchie said:
what does the stem feel like when you turn it :  Does it feel gritty or difficult to turn? Did you notice if it's always hard to turn when the hands/the stem reach the same position?
Not difficult, more like it wants to turn in 5 minute increments. Normal-loose-Normal-loose
4 minutes ago, clockboy said:
If the stem feels really loose then it could be the canon pinion slipping. If tight it could be a dial washer missing or perhaps the hands touching.
Stem is normal, and time keeping has been perfect and matches my timeographer readings. I'll take the dial off this evening and check for a dial washer. Wouldn't touching hands affect the time keeping? they're close, but I don't think that close.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
