How to open an old Elgin pocket watch?
wow,  nice chart, i copied for referance.  with some minor math  you should be able to select the amount of dome on a hunting case acquired with no crystal.!  measuring  the opening in the bezile accurately is the next step.  good luck.  vinn
Well it's been awhile since I worked on this one. I thought I was nearly done, having finally found a crystal. Thanks to whomever mentioned Dave's by the way!
Anyway, I pulled it out tonight to measure for the crystal and I noticed that will the balance wheel was beating and the second hand moving, the hour and minute hands aren't. It appears the other wheels are engaging and moving but for some reason the hour and minute hands aren't moving. Back to the drawing board this weekend! Any suggestions?
  • 9 months later...
OK I know it has been awhile but I have an update with a question. I have received another crystal that I am going to try and fit today. I pulled the watch out the other day to remeasure, gave it a wind, and the second-hand get running right away. However, I noticed two things one which seems very unusual. When winding the watch, the minute and second hands turn. That seems strange. When pulling the lever to set the hands, that seems to work properly except once I have it set and push the lever back in, the second-hand ticks but the hour and minute hands do not move. Hope this makes sense. I was really hoping to have this one finished today finally but it looks like I am having bigger issues which are going to require a strip down again. Any advice would be appreciated.
  • 3 months later...
Well I know this is a very old thread but I'm going to finally attempt to finish this this weekend. I believe I have found a crystal but before putting it in I'm having some issues. While the second hand is moving and appears to be operating as it should, the minute hand is not moving. Also, with the lever pushed in, the crown will still turn the hands while winding. What could be causing these issues???
Sent from my SM-N900V using Tapatalk
It sounds like a cannon pinion issue.  Has it been snapped back in place properly?  If it has, it could be needing tightened.
I'll take a look. Was hoping to have an idea before I broke her down again. Thanks Geo that gives me some direction. I'll let you know what I find.
Geo everything appears fine unless I misunderstand the function. The center wheel turns the Canon correct? Is it possible this is not happening because it fits too loose? Does there need to be a crimp or anything to hold it?
The cannon pinion should be slightly tight on the centre pinion to allow slippage when setting the hands, but tight enough to allow the hands to be driven by the pinion.
Have a read of this thread it may help you.
Geo I actually found the problem. The lever that pulls out to set the watch actually had a loose screw and so it wasn't actuation the way it should. Tightened it down and now she is working ok.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
