Hi All
I have a Maurice Lacroix Masterpiece Reveil (similar pictured) and need a replacement escape wheel (which i understand is an obsolete part)
I am told the model is 22197 with a cal AS 5008 (5611)
Would anyone on here have any ideas where I might source the part, the watch is lovely and I would hate it to be the end of its journey through life. (the movement has an integral alarm which may make replacing the whole movement difficult also)
Thank you for your time
Dan
13 minutes ago, Mark said:
The best thing to do is contact as many material dealers as possible.
Here is a good start: http://www.watchrepairtalk.com/links/watch-clock-repair-suppliers/
The Part number is 705 and the base calibre is 5001.
I could not find one at Cousins or on Ebay. You could try May at Northern Watch & Clock Supplies - she often has long obsolete parts. https://www.linkedin.com/in/may-moorhead-69887b38
Thanks Mark, most appreciated for your time, I almost sent this watch to you when i got it, but you were not taking anything else in at the time.
you were my preferred repair guy for this project after I have been following your work and videos :Bravo:
20 hours ago, rogart63 said:
Have you check with Mr Kudarsson at oldswisspartswatches . He has spares for AS 5001
Thanks, I had a look for him / his site, is the name correct please?
i am getting no luck around the planet at the moment
Out of luck at
On 27 April 2016 at 6:41 PM, Danh said:
Sudarson had one :woohoo-jumping-smiley-emoticon:
i have just paid, so happy, thank you
Sudarson could not find the part, but I then had a surprise text off May at Northern Watch and clock they had one.
amazing service , it arrived the next day :)
That's fantastic I'm glad you were able to find the part required to keep that beauty alive .
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
