Generally, Seiko barrels are not meant to be opened. You can still open them insisting a little..
Some like the 7005 have a split in the middle. Insert a sharp knife an twist that a little to open the barrel. This picture is a 7005 and you can see that split.
Also a word of caution diamondslayer.  The grease they use in many Seiko barrels is horrible black stuff the makes a nasty mess of anything it touches.  Open those Seiko barrels is my least favorite job :(
48 minutes ago, diamondslayer said:
How do you clean them if you don't open them?
You don't need to open the barrel, you can clean round the arbor with rodico or peg wood which is sufficient enough.
You do need to open them ;)
They have a slightly different cap than a standard barrel. Much the same as a valjoux 7750 barrel. The cap has a rim which extends right down to the barrel teeth tricky to open without damaging the barrel teeth. I find an extremely sharp razor blade is perfect for opening the cap.
On these seikos the mainspring has to come out as they are usually in an awful mess.
Also - note the orientation the mainspring is wound in. It will be the reverse of most Swiss watch barrels.
  • Thanks 2
Thanks Mark. To be honest the only 7S26 barrel that I've opened wasn't difficult at all, and no mess was found inside. I did replace the mainspring, but that didn't seem to make much difference.
Mark I don't know if you are aware back in  70's and 80's Seiko advised repairs if the the watch was 5 to 10 years old you should replace the whole barrel and not to open it to clean. Up to 5 years there is no need to do anything apart from cleaning the arbor.
Not aware of this - but for two decades I have always opened them up and done what I do with every watch :)
Actually - I have made a video of my method, write or wrong, and will upload it now so you guys can see how mucky they get, and this one was not too bad, Ive seen worse.
I shot a whole video for the 7S26 but have not finished editing it yet.
Edit... @oldhippy, I can see why Seiko would recommend this actually as the mainsprings can be damaged very very easily on these.
We all have our different ways Mark. I think that is one reason why seiko barrels are different and can be hard to open. I look forward to the video, for me its nice seeing other watchmakers working and how the go about their work.
1 minute ago, oldhippy said:
... for me its nice seeing other watchmakers working and how the go about their work.
Very true - one of the reasons this forum exists :)
Still the case today. Only barrel complete has a part number (if one can obtain the actual part). Which doesn't mean tha one can't open it anyway and replace MS with a generic part for a small saving.
One thing to mention about not only the 7s26, but many of the older Seiko movements, is that the lower arbor hole is often badly worn and needs to jeweled.  This is because they ran the arbor straight steel to steel, without a bushing.  Without regular servicing intervals these tend to wear badly and put the barrel on a slight tilt, causing the movement to have a lower amplitude.  In severe cases the barrel has tilted so much it's worn the plating off the top of the barrel as it rubs on the bridge, and the brass is exposed.
This fault is seen so frequently where I work, that even if the barrel is fine we jewel the hole as part of the service: as preventative maintenance.
NO FAIR MARK!!  You got a clean one. ^_^
Why do I always get the barrels that look like they've been filled with Track-Roller Grease! :pulling-hair-out:
NO FAIR MARK!!  You got a clean one. [emoji5]
Lol. Believe me - I've had them.
We get them from our parts department  :P
Seriously, I'm not sure of the cost mate.  We charge it out as "Auto Calendar Service" which is a flat rate of AU$495.00 for any standard 3 hand automatic movement with a date complication.
Sorry I can't be any more specific ... but you simply measure the arbor diameter (ID)  and the broach you used to re-round the hole (OD) ... add a couple of thou to the OD for a press fit, and also check the ID for correct side-shake to get the correct jewel.  Some plates require more broaching then others ... so the size you use can vary slightly for each movement.
I'm sure Mark will make a step-by-step video on jeweling worn bushings one day and it will be all clear.  It's not a difficult job with the correct tools.
I'm looking forward to this very much!
Cheers,
Bob
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
