Cleaning the corrosion after a leaky battery
In this case, the underside of the crystal is flat so I assume I don't have to worry about clearance to the hands. However, perhaps I'm missing something. If so, please let me know. I guess no one has the patience to get into the details of my first post so here's a simplified version of my question: The case diameter for the glass gasket is 36.9mm. However, Cousins doesn't have a glass gasket with that diameter. The closest are 36.8mm and 37.0mm. Would any of those two options work, and if so which one? I have no problem ordering both and testing them, but If someone already knows that it is pointless, there's no reason place any order at all. No, I haven't. Is there someone you can recommend? Preferably in Europe. Thanks!
By rjenkinsgb · Posted
No. It's incredibly volatile and evaporates in seconds; there is no way it would last as long as it took to just install the part cleaned in it, in the movement. -
When I record how much I have spent on each watch I include the postage. UK EBayers seem to be charging £5 minimum these days on postage. Have made a couple of job lot buys recently - based on the average price this one could be 404 reboot project Bad photo from eBay - 1 of 4 watches for a total of £21.19. A Medina with an MST 385 movement - Soaked in oil but looks like it will run again!
Thanks to everyone for your help. I am simply amazed at the knowledge of you folks. You are all truly "watchmasters".
I've used them for other hobbies and jobs I've had in the past, just wondered why people didn't use them in this. I may get some out and give them a go. However they're most likely magnetic so probably no good
