Seiko Dial
Hi
There seems to be a few people on here know something about Seikos, so hopefully someone can help :). I have this nice little Seiko 5 (case ref 7009-6000A) that looks to me like someone has cleaned the dial with acetone or similar. All the painted on writing and lines have gone, including the reference number I think is usually on the bottom of Seiko dials.
How would I go about finding a replacement if I don't know the reference? Will any dial from a similar watch fit, or does it have to be specific? I think I would have needed a new dial anyway as there are no feet on this one, although I am not quite sure how it fits given the full size day/date rings. I wonder if the dial is supposed to fit to the movement holder? Anyway, any information welcome - thanks!
Stephen
Seiko from this period tend to have similar if not the same No. as the model number on the dial, it would probably be something like 7009-60xx followed by 2 or 3 letters. The 7000 series movements normally have a plastic movement spacer, the dial feet push fit into this & are not screwed in. Not too sure but I would suspect that a dial from a 7006, 7019 or possibly a 7S26 would fit. Try fleabay or speedtimerkollektion.com.
Thanks guys. The watch came to me in pieces so I'm not sure what goes with what. The movement does seem to be a good fit for the case, which as I said is referenced 7009 600A1. The only marking on the movement is 7009A. I've just noticed the day ring is additionally marked 870044Y, don't know if that is relevant.
I've had a closer look and it does have holes around the edge of the plate for dial feet, didn't notice that earlier. I'd reuse the dial I have if it had feet, and if I could do anything about the peculiar finish it has on it now. So now I need a dial with the feet in the right places as well.
Stephen
Here is the model number that the dial came from.
http://www.watchsleuth.com/seiko5finder/search/?MOD=SNK631
My guess is that someone tried to use the dial and botched it.
The SNK is a 3:45 crown, and the 7009 is likely a 3:00 crown, which means the feet won't fit unless you have the right holder.
I think you will need to use the Seiko Finder to look for something similar for a 7009 where you can find a donor watch/dial, or go to Dagaz or any number of other suppliers and find a suitable replacement.
Good Luck
Thanks a lot for that, much appreciated. I have attached some more photos. You can't see from the first one but the case does have an offset for the crown - I would have just said at 4, glad to have your more precise information ;).
Sorry for the blurring on the next one, I was just wanting to show the  sockets on the plate for the dial feet. They do seem to correspond to the brighter markings on the back of the dial where I assume the dial feet used to be. As you can see there is evidence of glue, so perhaps as you say they weren't quite in the right place and someone tried to glue it on to the holder.
This last photo shows the two holders/spacers with it - not sure which fits where. Not sure any of this matters really as the dial I have is the wrong one and unusable, so I'll need to find a dial that fits the movement anyway.
Stephan,
Here is a great resource for/when working on Seiko's.  (BTW, 3:45 seems to be what Seiko aficionados use, while Seiko uses 4:00...go figure).  Here is the link, just scroll down till you find 7009A and download the file (PDF format).
http://www.thewatchsite.com/14-user-manual-technical-manual-casing-guide-downloads/15-seiko-calibers-technical-repair-manuals.html
almost all seiko dials are 28.5 mm. which means you can use almost any seiko dial that you like. i believe the only dials that you cannot use is the manual winder dials. quartz dials can be used if you want to modify them around the date window. not all dials will match up with the locations of the dial feet, tho.
here's your chance to really mod this watch if you want to. you just need to get some dial feet and dial dots.
you can even use a dial with date only - or no date at all.
its a shame about that original dial. that looked cool with the rally stripes.
    • Hello forum, I have just joined the forum and I believe it is the done thing to introduce myself.  I am based in Surrey UK and am essentially a complete novice at watch repair.  Fairly life long interest in watches, starting from not being allowed one as a child as I kept taking them apart… After watching a you tube video of a watch service, I thought to myself “I could do that…”. Well I got myself a Seiko 7002 dive watch that was a non runner. Striped cleaned and reassembled. With much blaming of tools, dropped parts and feeling out of my depth I got it working again. I built my own pressure tester and it leaked like a sieve! fixed now though.    I’ve since done a few 7002’s and an NH35A with mostly success. But now I’m left with quite a few working movements and no budget for cases. Overall my lack of a timegrapher has really hampered things and efforts using phone apps have been disappointing.    I next moved to an ETA 2472, all went well until I snapped the stem after failure to find a suitable case for it. Alas replacements seem almost the price I paid for the movement! Hopefully I’ll stumble on a suitable one one day.   Currently working on a Smiths 512 pin pallet movement. All went well until the shock protection. My goodness they are tricky compared to all the others and now I’m down one shock spring. This was my first movement I’d done with no video or walkthrough or even manual for backup. So I was pretty pleased with my self, briefly.  Well, that’s me and my watch repair journey.    Rob
    • Something odd is going on with email notifications. As I posted above with the screenshot, when I checked my notification settings I saw that somehow the option to send an email notification in addition to the browser notification was not selected, even though previously that had been working for me. So I selected the email option, in addition to the two top options of automatically following new content I post or reply to. I did not get an email notification for your post (I did get the browser notification), which I should have (it does show me as subscribed to this thread) and when I went to look again at my notification setting, the board software has again unchecked the email notification option (in addition to the two top automatically follow options). The below left is a screenshot of how it was setup after my last post and the right is how it was just now when I rechecked. For some reason the board is resetting this preference on its own.
    • I feel like I've achieved the next level up 😅 . First watch with homemade part installed ( setting lever ). FHF 73, not bad to work on, simple and sturdy, and part working perfectly.  An Avia and in time for this year's Olympics.  It has a teenage dial ( bit spotty ) 😅
    • We need to know the caliber.
    • I am.  On my phone just using the bell symbol, I don't bother with email notifications.  Actually I  stopped receiving email notifications a long time ago, I  don't remember cancelling them.
