Oiling A New Movement
I have a brand new pristine ETA 6498 movement. Still in the plastic box with a stem and temporary crown fitted.
I can oil the various jewels but do I need to. Also do I have strip the movement and correctly grease the keyless works and stem.
What about greasing the mainspring.
Or can I just fit it into the case and run it assuming that it has been correctly oiled at the point of manufacture.
Thanks for any advice.
Picture posted but the lighting isn't what it should be.
Edited by Alaskamick
Years ago if I needed a new movement it was always ready to go just fit dial and hands put it on the timer and all done. Today I would think it should be the same, besides wind it a little you should be able to tell if its dry, look at the top plate jewels does it look as if its been oiled, I think you'll find it has, the same with the action of the balance, if its looking good and has a good action I think your be OK.
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
