Remove Extra Links From Tag Heuer Link Band
stevegnh
Hi All,
I've scoured the internet and been unlucky in solving this question for myself. Then I found this forum, and I always find they are terrific resources.
Anyway, I have a 10 year old Tag Heuer Link automatic chronograph watch. I love it, but in the last year, I've lost a bunch of weight, and it's way too big now. I have removed all of the easily removable links (where you can slide the pins out), but even with all of them out, it's too large and can spin around on my wrist. Is there any way to remove two more links, one from each side? Is this something that requires custom work for a jeweler or someone to drill them out or something? I love the watch but don't wear it much because it's so loose.
Thank you for any advice you can offer.
That's a nice watch and good quality pictures Steve.
I don't think there is an easy way of removing these links, I think the ends of the pins are welded to the links, hopefully someone can confirm this. The links that you need to remove would have to be destroyed by grinding the welds away before the pins could be knocked out.
I may be completely wrong, and would like to here another opinion.
None of the links on that model of tag have a split pin/pin or tube, etc, they're all fastened inside of the link itself, you punch out the pin and remove the tube securing the bracelet to the clasp, on whatever side you wish to adjust, one side of the first exposed link will slide off, then a screw is exposed you have to undo that screw and take each link apart individually.
Ah I see, Chainstay beat me to it, with helpful videos as well.
Edited by Ishima
Oh man, now I remember! Call me D-U-M-B. I totally forgot how the Tag band was setup. Once you mentioned the screws Ishima, it all came back to me! The band is infinitely adjustable, not a certain amount of links. I just pulled our one link, and increased the micro adjust on the clasp out one, and it's perfect. I love tihis watch, but since losing 50 pounds, it was fitting any more and I've been bummed. One thing though, that I never got, was that little screw on the tube. Seems like you don't actually have to unscrew it, as the link just comes off it. It's slightly larger than the tube itself. I don't know, but they are all like that.
The only other thing that bugs me is since the last service, I noticed the crystal isn't laying flat. It's raised on one side, and flush with the bezel on the other. I've thought about buying a watch repair glass press, to push it out, put a new gasket/ring in, and press it back in, but I'm wondering if I'm better off just getting a watch repair place to do that. You can kind of see it, but not sure it would show in a picture.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
    • Yep, that's exactly how it should fit. The reamer shank is tapered and the socket in the spindle is also tapered so that the one centers in the other and is gripped tightly. If there is any wobble when the reamer is seated as far it will go then there is a problem. The cross hole in the spindle is to allow you the push the reamer back out again. If the reamer seated much deeper then it would limit the access for pushing it back out again. Here is one of mine for comparison.
