Having just started watch repair as a hobby, I would like some help on the basic Oil that I should be using for the different components of the movement. There are too many selections and opinions out there.
You can start out using two oils one which needs to be thin for the balance and one slightly thicker for the train,winding parts and mainspring. I retired a few years ago so I'm not up to date on what oils are on offer in this present time.
I don't think I have the oil required to oil the balance cock assembly, pinions etc?
Oils I have purchased so far.
1. Moebius 9010
2. Moebius 9104, HP1300
3. Moebius D-5
4. KT22
5. Pocket watch oiler (not sure the viscosity)
From Canada
From Canada
9010 is fine for cap jewels.
Understood, thanks. Seems like 9010 is good for most parts, not sure how to oil individual gears and teeth or if it is even necessary.
From Canada
You will need the maintenance chart/service data for the movement and oil where it tells you to. No oil on gears and/or teeth! Only pivots and jewels and some other rubbing parts.
And I was also told 'NEVER OIL PALLET LEVER PIVOTS' - so, that's what I was told.
You already have more different kinds of oil than my watchmaker...LOL
I live in Saskatchewan. Where are you?
Dave
Dave
i am in Ottawa . Thanks for the advise
Dave
That is correct. You can oil the pallet stones with a very tiny drop of oil but that is all.
The basically part worries me...
Also, d5 and Hp1300 are used in the same spot, either one or the other. If the movement is low bit you can use 9010 in the pallet jewels in a pinch. You only use 9415 or 941 (for low bit) in the pallet jewels and you don't list them, so I guess either 9010 or get some of the real product just in case.
