SCOTTY
After I got my Elgin 313 running today, I watched Stian restore an oil-drenched Soviet Pobeda Zim. I found one similar (in stainless or nickel plate) on eBay and it's on its way. The one shown is the one Stian worked on. Simple three-hand movement. First one I've purchased to work on actually in a case...  🙂
Good deal Gary ? You tackling the Elgin lack of power transfer today ?
To answer the question "How much pocket watch can you get for 99 pence?" (plus shipping obviously), I picked this up.
I think the answer is "Nearly a whole one."
It claims to be "15 Jewel" and "Swiss" and it obviously needs some work (and a stem tube, stem, crystal and crown at the very least). Good job I lie a challenge, I guess. 🙄
Here are a couple more pictures of the mystery pocket watch
Sadly this last one is the only picture of the 15 jewel Swiss movement, so it remains a mystery what exactly I have picked up for my 99p.
9 hours ago, grsnovi said:
Soviet Pobeda Zim
@grsnovi Here is a little history and info for that USSR watch maker-> https://en.wikipedia.org/wiki/Pobeda_(watch)
It probably as this inside -> http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Pobjeda
More info here -> https://17jewels.info/movements/z/zim/zim-2602/
I've a bit of a soft spot for USSR era mechanicals (and Indian  HMT mechanicals too). They are generally easy to work on, although the quality is a little variable to say the least.
Edited by AndyHull
On 5/5/2022 at 11:00 PM, grsnovi said:
Soviet Pobeda Zim
I gave up on this one. I didn't notice that the seller was in Ukraine when I made the purchase and the watch doesn't appear to have left Ukraine. I'm guessing it isn't going to. It would have been a nice addition.
  • Sad 1
I have another Buren Grand Prix coming. Hopefully the keyless works is the same as the one I had previously started on. The movement appears to be the same size. I'll do a better inspection of this one once it arrives and I'll also take a good look at the pallet and balance on the one I already cleaned (since I seem to be destroying parts during cleaning). My microscope is supposed to arrive tomorrow. We'll see.
9 hours ago, gbyleveldt said:
I need help…
Working on all of those watches? 🙂
7 hours ago, RichardHarris123 said:
£2.20 so I don't care if it is rubbish
I wish my recent purchases were for that amount...   🙂
10 hours ago, RichardHarris123 said:
I'll let you know it it was worth it.
Of course it was worth it matey .2 quid 20   Half a Costa coffee against hours of frustration and anguish. You know you've made the right choice, what else would you be doing on a lazy Sunday afternoon. 😊 . No time to worry now.
Edited by Neverenoughwatches
If nothing else, it will be good practice trying to get the case back to so form of decency.
I'm shocked! The Pobeda showed up today! 🙂
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
