Case Opener
hokavan
It looks like a screw type. If correct it will depend on how tight it is for the method used to remove. The sticky ball method is not good for the really tight one,s. Some members have attached a bolt to the back using supper glue undoing with a spanner then cleaning the back afterwards.
Last year I bit the bullet & purchased a Horotecc case opener which is the best opener for the screw types, but you still need the appropriate die,s for the various makes.
A better pic will help.
If the case back has serrations does that mean your looking for jaws with a triangle end that you attach and turn anticlockwise? I've never come across this type of case back
Sent from my SM-G900F using Tapatalk
here is the correct tool for Rolex type case backs
550f42b6-3b30-4a16-a2fa-a265da3c4768_zps
Edited by Andyclient
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
