Smiths Pocket Watch Repair Help?
bosstaki
Hi guys, does anybody know how to disassemble this pocket watch? Or know how I can let the mainspring down on this pocket watch? It runs if you shake it for a while then it stops running? Any help would be really helpful guys, cheers [emoji3]2168a086c79545c97abe8941955cc4f2.jpg455b5ea62e845d8c365b540dca0091c8.jpg
Easy one mate, to let the spring down you will need to hold the click back, it is located in the hole just to the right of the "F" on the balance adjustment. If you wind the crown a tiny bit you will see the click move, use a fine screwdriver to hold the click away from the mainspring barrel, keep control of the crown and gently ease the mainspring down . Hope this makes sense.
I'm afraid I haven't been able to find any reference material for pocket watches at all on the net, unlike seiko etc where you can download full technical manuals with schematic drawings. With your pocket watch it's a case of stripping it blindly and taking photos every step of the way on your phone.
First off id let the main spring down, then release the movement from the case, two screws hold it in, then I would remove the hands, then dial ( careful you don't break the tabs holding the dial on) .
Now I would take off the plate that covers the main spring barrel and lift out the mainspring barrel.
Now proceed to remove the other screws that hold the plates Together, before you seperate the plates have a look at the hairspring and balance, the hairspring is pinned in and will lift out with the top plate but be careful of damaging it. If you are confident enough to re pin the hairspring ( it's quite easy just take your time ) then push out the brass pin now and then lift the plates apart.
Take note of the layout of the train, now remove the train, you will also most probably have had the setting mechanism shoot away from the movement when you seperated the plates. Put this to one side and once you have the train out try refitting the setting mechanism so you know how it sits at the top of the movement.
You should now have the watch in bits, congratulations now it's time to inspect and clean and get ready to reassemble. Let me know if you need any more guidance, I might have a few photos of a previous strip of a smiths movement that I could post to help you out if needed ok.
The balance staff very often in these movements wears down to what I can only describe as a blunt pencil, so it might need to be re-pointed this can only be done by lathe work, make sure the balance cups aren't worn. These are very easy to repair and shouldn't cause any problems. Good luck.
Whats the best way of repairing the cups mate, I'm pretty sure these are the biggest problem to non running movements like these "dollar" ones. I've cleaned and peg wood pivot holes oiled etc etc and still get an eratic runner and everything seems to point to the balance
  • 3 months later...
I've just aqiured two, both with the same issue and one of them has a stainless steel case. One is 1972 and the stainless one is 1973.
The 1972 one I took apart and gave it a good clean and lube, plus a new mainspring. After a few winds she started going, but after a full wind it stopped after a while. I noticed that under tension the barrel was lifting out of alignment and thus jamming on the barrel plate. I guess that would be worn pivot holes in the plates and possibly the barrel arbor hole as well.
It'll be good fun drilling the holes out and fitting some bushes. Still worth the effort I think, just to keet it going.
I've seen a few old pocket watches online where repairs were carried out for similar issues by using a hole reducing stake. Yuck.
  • 3 years later...
1 hour ago, Fatfinger said:
Hi I'm a 80 year old newbie to the watch hobby and would like some help. I  have a Smith's pocket that works well in the upright position but stops when laid flat . Can anyone help
Dial down stop indicates a fault at lower( main plate side)  balance pivot or it's jewel assembly.
I loosen the stud screw, remove balance+cock and disconnect the two( balance complete and cock). Check if a lower pivot exist, if so, a close up of the pivot under high magnification helps, if you have no access to high magnification, I drag pivots on a flat side of tweezers, a broken pivot feels different drag.
Good luck.
The balance staffs on these movements should be like a sharpened pencil for the balance to operate correctly, as soon as they wear and go blunt the action slows down and eventually will only work one way. Also the cups also wear inside. The way to repair this is too remove the entire balance, remove the hairspring and re-point the staff on a lathe using a stone and a little oil. A small Arkansas stone is needed. If the cups are worn in side then a right size chamfer drill should be used. The only other way is to find a good unworn replacement.
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
