Not to say you should do this but I purchased a lot with about 50 movements in it (maybe more) and strip them down as needed.  For now, I am somewhat organized with it and can "pull" parts from specific movements.  Wish I had your model movement, I'd be happy to send you that screw!!!!  Good luck, thanks for keeping us posted:)
i tried yesterday to find a screw but no luck.
Today found a watch service where the guy had a screw of the width i needed but
he didn't pay attention that the tip of the screw of getting out. (I didn't also probably due to the excitement of getting one step closer)
When i putted the bridge in place i found it was not flat which made the main spring barrel getting out of its whole when i rotated the watch and as a result the watch would not work.
On the quest to shorten the screw i lost it :D, it is somewhere in the room but i have given up searching.
i assembled the watch, fitted back the dial and the hands, gave some rotation to the ratchet wheel.
below is a sample of the watch working, it has been working for the last 2-3H.
https://www.youtube.com/watch?v=1TLvipEkQwQ&feature=youtu.be
i will see for some glue to fix the original screw in place.
What a pity, drini. You were almost there, I feel for you. On the other hand you have done a great job fixing and giving maintenance to that watch! Cheers,
Bob
Well i managed to fix the screw and after 2 days of testing the watch is working.
I haven't fully recharged the main spring as i fear the crown wheel will pop off :).
From checking the watch during these two days i see that is working 1-2 second  ahead of the watch in my PC, i have tried many times to regulate the beating of the balance by putting it in the slow motion but as i see it the watch always finds a way to speed up :)
THANK YOU TO ALL OF YOU FOR THE SUPPORT/SUGGESTIONS YOU HAVE GIVEN ME DURING THIS TIME :)
Operation can be called finished
Congrats my friend, you deserve a huge pat on the back for your success!  Plus, you didn't loose your temper so I have to say you are a perfect fit to do this as a hobby;)
thanks guys for the compliments, but to tell the truth i did lose my temperament but took it out on my tools :D :D.
As for the new project i will start disassembling my old CASIO EDIFICE(1st watch i bought with my money). it is nearly 9 years old and from the outside is Ok but i now that the inside needs some cleaning.
As for a project like working on an old watch, i have to think about it.
i have to consider the cost i have to invest in such a project(buying a not working watch + parts) but will keep an open mind on it :)
Hi drini,
Great job!
Now a word of caution: Casios are mostly either unfixable (no parts from Casio) or have movements from Citizen or Seiko that most likely are not available to the general public, not serviceable or a royal pain in the rear to do that. Not my first choice for a repair/learning watch.
Cheers,
Bob
I've broken my fair share of tools and movements due to aggravation, especially in the beginning when I had cheap tools...I have since learned to calm down, walk away then do a little yelling in another room;)
LOL, I'm compiling a "Cursing Guide for the Frustrated Watchmaker or How to NOT Screw Up Further by Releasing Steam", with stuff I come up when I'm mad at my watches! There are sections of "Proper Cursing When an Irreplaceable Part Pings Away", and "Proper Cursing When YOU Really Screw Up: Your Fault" and of course a "Best Practice for Cursing in Watchmaking" and "Compendium of Effective Coursing Expletives" as bonus chapters! :D
Yes! I need to expand my vocabulary instead of just dropping f bombs and shouting [EXPLETIVE DELETED] over and over!
