Disassemble Doxa Dial
drini
Not to say you should do this but I purchased a lot with about 50 movements in it (maybe more) and strip them down as needed.  For now, I am somewhat organized with it and can "pull" parts from specific movements.  Wish I had your model movement, I'd be happy to send you that screw!!!!  Good luck, thanks for keeping us posted:)
i tried yesterday to find a screw but no luck.
Today found a watch service where the guy had a screw of the width i needed but
he didn't pay attention that the tip of the screw of getting out. (I didn't also probably due to the excitement of getting one step closer)
When i putted the bridge in place i found it was not flat which made the main spring barrel getting out of its whole when i rotated the watch and as a result the watch would not work.
On the quest to shorten the screw i lost it :D, it is somewhere in the room but i have given up searching.
i assembled the watch, fitted back the dial and the hands, gave some rotation to the ratchet wheel.
below is a sample of the watch working, it has been working for the last 2-3H.
https://www.youtube.com/watch?v=1TLvipEkQwQ&feature=youtu.be
i will see for some glue to fix the original screw in place.
Well i managed to fix the screw and after 2 days of testing the watch is working.
I haven't fully recharged the main spring as i fear the crown wheel will pop off :).
From checking the watch during these two days i see that is working 1-2 second  ahead of the watch in my PC, i have tried many times to regulate the beating of the balance by putting it in the slow motion but as i see it the watch always finds a way to speed up :)
THANK YOU TO ALL OF YOU FOR THE SUPPORT/SUGGESTIONS YOU HAVE GIVEN ME DURING THIS TIME :)
Operation can be called finished
thanks guys for the compliments, but to tell the truth i did lose my temperament but took it out on my tools :D :D.
As for the new project i will start disassembling my old CASIO EDIFICE(1st watch i bought with my money). it is nearly 9 years old and from the outside is Ok but i now that the inside needs some cleaning.
As for a project like working on an old watch, i have to think about it.
i have to consider the cost i have to invest in such a project(buying a not working watch + parts) but will keep an open mind on it :)
Hi drini,
Great job!
Now a word of caution: Casios are mostly either unfixable (no parts from Casio) or have movements from Citizen or Seiko that most likely are not available to the general public, not serviceable or a royal pain in the rear to do that. Not my first choice for a repair/learning watch.
Cheers,
Bob
I've broken my fair share of tools and movements due to aggravation, especially in the beginning when I had cheap tools...I have since learned to calm down, walk away then do a little yelling in another room;)
LOL, I'm compiling a "Cursing Guide for the Frustrated Watchmaker or How to NOT Screw Up Further by Releasing Steam", with stuff I come up when I'm mad at my watches! There are sections of "Proper Cursing When an Irreplaceable Part Pings Away", and "Proper Cursing When YOU Really Screw Up: Your Fault" and of course a "Best Practice for Cursing in Watchmaking" and "Compendium of Effective Coursing Expletives" as bonus chapters! :D
Yes! I need to expand my vocabulary instead of just dropping f bombs and shouting [EXPLETIVE DELETED] over and over!
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
