More On The Harwood Watches
cdjswiss
For those of you who have read and were interested in my previous post on Harwood watches (the first automatic watch) here is another interesting example. This one was marketed by Blancpain in Barcelona around 1930. The hand setting is now done by turning the watch back and there is a four-cornered screw head (arrow) that turns against a leaf spring to adjust the pressure of the slipping clutch that prevents over winding.
Nice watch Colin, you certainly know how to get my attention. Does the back just snap off and are you going to service this one?
The back does indeed just snap off as does the font bezel. The movement is front loaded with two half-head screws to hold it in place. This arrangement makes it less dirt proof than the more conventional Harwood.
I have just done a complete service and it is now keeping time to better than one minute per day. The silver dial with gold numbers is original and has just had a light brush over to remove a little dirt.
Harwoods have a reputation of not running for more than 12 hours, but this is nonsense. The power reserve depends on the Schild movement and is well over 24 h. A mal-adjusted automatic winding system probably accounts for poor performance. But this one I have worn 16 hours per day and taken it off for the 8 hours overnight and it has not stopped since I began to wear it on the 1st January.
The Spanish patent number on the winding bridge is a mystery - some have attributed it to the back-setting feature, but it cannot now be found in any Spanish official record. It is thought that perhaps, although filed, it was never granted. The novel slipping clutch screw adjustment permits easy and stable over-wind protection. I wonder if this was a Blancpain add-on?
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
