Will This Jeweling Staking Set....?
diamondslayer
I've bought from this seller before and I'm very satisfied with his items. He is kind of fair on the prices but not cheap. What you get is careful package and products sometimes better than expected. He appears to know about watchmaking or at least its tools. I would ask if the set is compatible with the Bergeon parts (stumps, stakes, etc) and since it has a jeweling attachment if it is also compatible with Seitz parts. If so, I'd say go ahead...
This is what you are looking for to get the same versatility: Two different tools at something like this: Bergeon Staking tool = US$1000 and Seitz Jeweling Tool = US$1000....approximately.
Of course, I'm new to this too so maybe more experienced people can jump in and expand on this. I'd love to "hear" from the pros. Just as this is my own opinion but hope it helps.
Cheers,
Bob
Although I agree with syfre, I still think it would be a great addition to your tools. Example: A Seiko 7S26 gently used, when tried to repair the post for the intermediate wheel (the one that changes the date and the day) came apart. I used my staking tool to fix. In another instance, another Seiko, this time a 7S36, bought non runner showed a cracked jewel...staking tool with jewel attachment time and movement fixed and running good. Later, a Unitas 6498 with a cracked jewel came along and the jewel attachment fixed it.
I can tell you many instances of new and not so new watches where a staking set will be useful. ...but YES, you don't use it every day. I for instance can count with my fingers of one hand the instances I've used mine in the 2 years I've had it....It all boils down to decisions and more decisions!  :)
Cheers,
Bob
As there is a thread about staking tool . I borrow it if it's okay? Bought a staking tool on auction? The tool or whats it's called is missing. Only punches in good condition. It's a Favorite tool . So now looking for the tool part. Could i buy any tool out there? the punches has a diameter of 4,7 mm . Found a nice old K D staking tool on Ebay . Would that work with my Favorite punches? maybe a little expensive? http://www.ebay.com/itm/OLD-K-D-Staking-Tool-Kendrick-Davis-Special/181962937077?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34881%26meid%3D0fc43b80682e43828bde98f9856be61f%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D181960702194
Rogart, I'm not sure. I will have to measure my K&D to actually tell you...I will do in the morning as right now it is not possible to get at it...It is 1am here and everyone is asleep. In my mind, they are about 4mm not 4.7mm so they might not fit...this is not a definitely answer...I'll tell you for sure tomorrow...or to say it properly, later today! :)
4.7mm is the "normal" punch size for staking sets if there is such a thing, but you could never be sure and just buy any tool. You would need to ask the seller to measure the internal diameter I would think.
Stephen
Stephen
I will wait and see what it is when i get it home? One day i find a nice favorite staking tool to go with my punches.
Edited by rogart63
    • Welcome! To which part of India will my greetings go? Frank
    • I agree with @Waggy, no need to adjust. That looks very good to me. The factory specs for 7S26 are something like -35 to +45s/day, but they are usually better. The amplitude is good. When wearing, the most important positions are dial up, crown down and crown left. You need to regulate so that these positions average out to about zero. Crown down is showing +14, so you may have to set dial up to slightly minus s/day. The absolute values of +/-s/day don't really matter, as long as they aren't too far out. The only way to get good accuracy is to wear it for a couple of days, recording the errors, and gradually tweaking.
    • @Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
    • Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
