1964 Seiko Re-Cased.....
Hi All ,
  I was surfing the 'Bay about 2 weeks ago and came across this 1964 Seiko Sportsman Seahorse , Waterproof , Diashock 17 jewel , With a very clean Seikosha 957 Movement . It has the old style model number on the case back and the serial number is 7 digits , not the 6 digits that they use now . The model # is J13082 .
It was being offered as a non-runner....as-is .
  It turned out that the balance roller jewel was not in the fork of the pallet and it was over wound . I remedied that pretty easy and although it does need a service , It keeps excellent time .
As I bought it...
This pic from the internet shows the movement....my movement looks very clean..
 I bought this NOS case and back with the original crystal , movement ring , and caseback gasket [lubed and in good shape] , and the original crown that says SW . I am not familiar with that designation so I asked around and came up with the consensus that it stood for "Seiko Watch "...I am not really sure of that yet....The best part is that the case is the same model number and the serial # is different by about 5 or 6 months of the same year . The case back still has the protective plastic on it .
And finally , here is the Re-Case....I like it.....
Thanks , I have quite a few Seikos and Citizens including new ones , vintage , solars , tuning fork , electric and electronic , quartz , ani/digi's ,radio controlled , and satellite controlled .  I also have an assortment of dive watches from both manufactures , new and vintage .
I have yet to get the Seiko 62MAS and the "Arnie", but I have a few 6105 models including a very clean 6105 - 8110 model with the original signed Seiko waffle strap .
that is a beauty! i'm really liking the yellow gold and stainless together. very well done on that combination. i'm still a sucker for those old hand wind seikos.
i used to not like that silver / gold combination until i walked into an aprilia dealer back in '04. he had a brand new '03 mille on the floor. it was silver paint with gold ohlins shock and OZ forged wheels. i'm a fan of that combination ever since.
did you get your case from a vendor named kidith by any chance? she sells quality NOS cases. picked up a few myself and am eying another.
EDIT: i just saw your reply to me on another thread. yup - kidith.  let me ask: how did you know that the case you bought would fit the seahorse movement? i've been toying with picking up one of the hand winder cases, but i don't know what fits into it.
Edited by ramrod
In this watch the model # was the same on both cases . J13082 , and the serial # was the same year with 5 months difference . On Ebay I searched for Seiko Sportsman Seahorse and the case came up . I believe  the Sportsman and Seahorse combo is not that common .
  The other case I bought from kidith was for an identical Seiko movement and dial of another watch I had that had the original case . I had already polished the original cushion case and installed a new crystal and when I found the same NOS case from kidith I got it . Both watches look great . You can't beat the NOS cases for a new look .  At the $19 kidith sells the cases for , you can't go wrong .
A few months back I was messaging kidith about the cases , trying to find out which Seiko 8 digit [ xxxx - xxxx ] case numbers  they had , and they told me that they bought out a supply from a closed down department store that had a jeweler , but they didn't know the first thing about the Seiko watch numbers . So I slowly schooled them . I also suggested that they join the SCWF so they could ask questions and possibly sell the cases there . I know that the forum members there would be happy to get these NOS cases .
  • 5 years later...
  • 3 months later...
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
