Hi
When balance running, the spring touches the last outer spring and make the watch running fast. Or is it touching because the spring is not lowered/pushed enough down on the balance? the I have seen the last few percent of the spring to be raised, if thats the solution, how can I manipulate it with tweezers?
Edited by Khan
It looks like the collet is not pushed fully down.
Also, it looks like the top pivot bent ?
You need to bend the terminal curve so that it is flat.
  • Thanks 2
The last 90 to 180 deg to the stud is rising, it should be the same level as the rest.
If you can see where rising starts, twist there with 2 tweezers. Else go back from stud max. 180 deg and twist. Not recommended for beginners.
Frank
46 minutes ago, Khan said:
Hi
There's more that just a bit of spare poking through the stud as well, is that doing anything it shouldn't be. And no don't cut it back , you may need it yet. The non flat is likely caused by a twist but it could also be a vertical bend near the end raising the last coil up. Hopefully its a twist easier to deal with, as frank says back 180° from high point but you should be able to see where the twist begins. Anchor with one tweezer just before the twist , other tweezer leave open just after twist, angle tweezer in direction required and then nip together gently but with purpose, then examine and repeat as necessary. No its not beginner's stuff, practice on scrap springs, the vertical bend correction is more challenging  and easier to overdo, lots and lots of practice.  I finally , a year ago found a couple of mediums that i like to press the spring into, thick dense cardboard or hard pink dehydrated sponge, the sponge is good/gentle as it allows the spring to sink in as well.
A uniform medium is easier to work with, i went off using timber there was too much variation in it to safely bend a spring's height profile.
Yes, there top pivot is a little bent, can it be corrected?
Theoretically yes. Practically, very difficult/near impossible. I have never managed without breaking it.
Do you have a staking set?
41 minutes ago, Neverenoughwatches said:
Just need the right tool Mike as with watchmaking tools.
Trust you to have the right tool 🤣.  Next time I need a pivot straightening, I'll send it over. You must have straightened hundreds without a single failure?
Those tools are as rare on ebay as rocking horse poo, and as new ones cost £642 and balance staffs are about £10, I'll stick with changing the staffs.
Edited by mikepilk
Attempted 3 success rate 2 😅,  another 30 or so saved and its paid for , 20 years maybe 🤣
Now I know what I should've invested in for retirement plan as I'm sure they didn't cost that at one time. Then if you had one of these rare tools yes it can work this have to be careful.
Ideally replacing the balance staff would be best but do we know which balance staff this is?
Usually there are 1 or 2 available on ebay at any given time for something like $250. Still a lot of money for a dedicated pivot-breaking device. A $5 tweezer works just as well..
Yep, just as easy to break with tweezers
Not too rare though and not too expensive for an old one tbh, i found two on ebay just now. You take your chances on if a jewel or two might be broken . I was very lucky at £120 in perfect condition,  i wouldn't have paid much more and the seller was kind enough to drop it from 150 to 120 my cheeky offer, so i figured it was a bargain. I see an attempt at straightening a pivot as nothing to lose and everything to gain. Out of 3 i broke 1 and that was complacency, too confident that i had success with 2, i didn't give the 3rd enough time in each jewel, i wasn't progressive enough so my bad. The upside is a potentially if not a high probability of a straight pivot. No risk of clumsy staff removal / rivetting up, potential damage etc. The straightening up i would say is faster and damage limiting for me anyway as staff replacement for me isn't my fortè, I'm ok but haven't done enough to be super confident and i haven't managed to cut a staff out cleanly yet. So in my experience the pivot straightener gets a 👍 if you can aquire one cheap enough.
It helps to have the right tweezers and the right procedure with tweezers. Yes like everything in the world there's procedures like if the tweezers a heated up not red hot but they have to be hot hot enough you can't actually hold the tweezers. When I was in school the instructor had the tweezers with strips of wood to keep you from burning your fingers. Then it hit it with an alcohol lamp and that's how he would do that. Plus of course the right shape of the tweezers conveniently I don't remember what they're called I'd have to get a picture.
Lol i wouldn't call it dedicated, if it's bent then it may as well be broken 🙂 But i see your point if it breaks a pivot at every attempt then you've bought something that does nothing. I figure Bergeon would be having plenty returned if at nearly £700 they didn't work at all.
I haven't done lots, but I have no trouble changing staffs. I punch them out with a Kendrick and Davis tool. Once you have selected the correct punches, it only takes a minute or two to rivet the new staff in. You do avoid some rebalancing if you straighten the pivot.
Probably more than me Mike , i rough guess maybe 15 or so. Doesn’t worry me but i always have that nagging feeling in my head that i should be cutting the staff out, if i can avoid that nagging i will. Maybe i can apply that theory to the missus 😅. Parts do need to be removed and accurately replaced to restaff, hairspring risk comes to mind, the whole proceedure is certainly longer, probably why the pivot tool is so expensive new.
Watchmaker and kindred trade tool catalogue,  one of the best links you've posted John 👍
Edited by Neverenoughwatches
Yah that’s a good way to think about it.  Since I have the pivot tool from my Seitz set I give it a go with the expectation I may be replacing the staff. I’ve had great success with the tool though, a great time and hassle saver when it works. I’ve only had couple two or three snaps out of six or seven, one while learning how to do it and one where I miscalculated the pivot width and went too small in the jewel hole…
…I don’t understand the heat/cool idea- ‘twas bent at room temperature and it didn’t snap so just bend it back. I’ve done the following for wheel pivots, too…
These ones I think John, the small set is Favorite and the large Dumont
Tom
Tom
Oooooh Tom , now I've got some tweezers this thick and i wasn't sure what they were for, still dont , but it could be adapted,  now i can sell my bergeon straightener lol
Interesting theory that the tool doesn't work at all except it does work and it seems to work fine at least on the couple of times I've used it.
Yes it's the large one that works fine for straightening pivots at least if it's warmed up.
We need the help of somebody else who's done this before which would be @nickelsilver
It certainly does work John. I'm happy with my 2 out of 3 and one of those was on an escape wheel.
Are the pivots on different wheels (escapement, gear train, balance) hardened to the same degree?
I wondered if balance pivots were less tempered and so more likely to break.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
