Boot Fair Bargain !
atimegoneby
I picked this up at a local boot fair a couple of months ago for £3, the chap I bought it from told me he'd owned it for around 40 years.
Although the crown is missing it just seems to have come unscrewed as the stem is present,
haven't done anything to it yet (not had time) but looking forward to it !    :)
I reckon that'll be a Raketa 2609.HA under the snap on case back.
A capable little engine with end stones for the escape wheel held in place with spring clips which can be a challenge to reinstall, a tiny little hole jewel set into the tip of the centre wheel pinion for the seconds hand pinion to run in, a lefty for the crown wheel screw (3 slots), a press fit cover plate for the motion works, and a shim under the balance cock. With what looks like a Russian version of Incabloc shock protection and an adjustable stud carrier it's a nice movement to work on and can turn out quite good performance.
In case you hadn't guessed, I have done one or two of these  :) .
Cosmetically yours looks to be pretty good so provided  no one has  brutalised the hair spring you should end up with a great everyday watch. If you get stuck for any spare parts let me know, I may have some bits and pieces in my goody box.
Funny you should say that, Marc. Here's what I'm wearing as an everyday watch at the moment.
post-1267-0-48623900-1446339845_thumb.jp
I wish I'd gotten mine as cheaply as atimegoneby.
Thanks for the info Marc,  that'll be really useful when I start to work on it.   :)
Phil.
Spot on Marc !
I started work on it today !
As the crown was missing I couldn't wind it but when I took the back off I gave it a couple of winds from inside & with a gentle shake it came to life.
It looks in quite good order except for being dry and some of the coils on the hairspring look unevenly spaced. I let it run for about an hour before taking it apart.
This will actually be my first proper strip of a mechanical watch, ( I'm really used to clocks, the odd pocket watch, & quartz watch movement swaps, etc ) so this will be a bit of a learning curve !  but everything so far has come apart no prob.
The only query I have is the centre wheel comes about halfway out & comes to a stop ?, I don't want to force it  and do damage, not sure what to do ?
so have left it for today.  :unsure:
That's a nice Sekonda is that a 34mm case? looks bigger.
Nice clean watch you got . Nice price too . I have a few Russian watches and I have seen the prices go up in the last year as they get more popular .
I have a Vostoc ships clock ....next to a Vostoc diver .
 I put a Slava watch on a Green canvas strap that seems to suit it . The Slava has 2 mainsprings btw .
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
