Making Case Press Die?
jdm
I'm having trouble closing a small fashion snapback - just as I had trouble opening it. I believe that is because the case back is oval and slightly raised in the center, so the die presses there, making it flex instead of pressing down the edges.
Has anyone had luck building a custom die from hard wood, filed to push just the edge of the case back?
Hi jdm,
I've had this problem many times especially with larger diameter watches & using nylon dies, the dies tend to flex like a diaphragm absorbing the force of the press. I have improvised with wood & it works, always a relief when the back snaps on though !.  Good luck !
Thanks, in my case (no pun intended) it's the case back that flexes, as the die is thick and strong despite being inadequate. I'll see what can I do with wood then. This is certainly an hobby of thousand trades.
I think your diagnosis is probably correct. I have found that a tiny bit of silicone grease on then rim really helps.
  • 4 weeks later...
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
