Seiko Dive Watches
Hi, I'm about to start having a go at repairing wrist watches.
I have found a seller on eBay with lots of Seiko Dive watches for sale quite cheap. Not Quartz, just wind up or automatics.
Can anyone tell me whether these are good to work on and are parts fairly readily available.
Thank for any advice..
Hey Alaska Mick. I think I know the seller you are talking about and yes his proces are good, but a lot of the watches are complete basket cases. If you want to get experience of stripping, cleaning, assembling, I would suggest snapping up one of the many job lots of cheap 'spares or repairs' mechanicals that come up of Ebay. Soemthing like this lot for example.
http://www.ebay.com/itm/Vintage-WATCH-LOT-of-5-parts-repair-ELGIN-10K-RGP-TRADITION-10K-RGP-WESTCLOX-6-/121793249895?hash=item1c5b718267:g:sKQAAOSw~bFWJuSX
These won't break the bank and will have simple movements that will be a good grounding in the basics. Plus, you won't be too upset when you invariably trash a couple (at which point they move to the ever growing 'spares' pile)
I presume you are talking about the guy in the Philippines?
Most look trashed but occasionally you can find a decent item or two.
Lots of 7s36 pieces with weld damaged crystal.
I got these to make into one good one.
Left one works. Replaced crystal with original new one. Dial missing 12 marker and incorrect seconds hand hence the not working one on the right for parts.
Each cost around £12.
I think most of us have encountered the ebay seller 'the watchcollector' , Most of his watch have issues but he usually groups them together so you can usually get one or two good ones out of a lot of typical lot of 4. Example, he will usually list 4 pcs of similarly cased watches with common movements.
In my experience the watches are usually honest working watches, ie they haven't had the better parts harvested.
Stay away from the ones where he says that the back cannot be opened, I have encountered some and they are an absolute '**BLEEP**' to open, in most cases I've had to heat the damm things.
Worth a shot as a learning experience but one thing that you'll have to live with is that practically all of them have worn winding rotors. The watch will work but it'll be a bit noisy! They're cheap enough and even if you fail to get any working you'll have a nice source of parts for the next round!
I'd recommend the 6309 / 6119 series of watches as they seem to have better quality...7xxx are slightly cheaper (to me).
Anil
I have had loads of watches from the same seller you are talking about and am rarely disappointed. As long as your expectations aren't too high and you understand what you are getting. I don't think there have been more than a couple that I haven't managed to get up and running even with my limited experience. To be honest some of them have actually been running by the time they are delivered, must be the good old shaking they get during transit. Maybe look for some of his that he describes as "running as is" or "runs for a while then stops".  One thing though, if you think you might need any parts for renovation etc like dials, hands and bezel inserts it's definitely worth taking a chance and ordering them at the same time as your watches. There is nothing more frustrating than having to wait for another delivery which can take around 2 weeks, not to mention the extra shipping cost. Ask me how I know :)  I have found him to be very helpful and has sorted out one or two incorrect items for me without any trouble and always answers emails.
Good luck
Dave
If you do buy from Ramon (thewatchcollector) and find you need/want to replace dials/hands......
Aftermarket but superb quality.
http://www.dagazwatch.com/apps/webstore
http://www.yobokies.com/
If you want new/used OEM parts.......
http://www.speedtimerspares.co.uk/
http://www.speedtimerkollektion.com/
Also Stefan AKA schillachi61 on eBay.
Bought bits from all of them. Well respected sellers on the Japanese watch forums. [emoji106]
Edited by ro63rto
    • So that is what the last person to work on this movement appears to have done.  There was a "wad" of adhesive material in the vicinity of that hole when I took the dial off.  I was hoping to take the high road and fix the issue in the work I did on this movement. I wasn't sure if I was imagining things or not when I looked at the screw hole, but it does appear to be somewhat distended.  I had not considered the posibility that someone had forced a screw that too big in there.  I had wondered about using a technique I've applied in other applications (where the screws are in the same scale as human hands) that involves counter drilling the plug with a  reverse threaded tap.  When I've had to do that in the past, the screw has generally caught and backed out from the torque on the tap (instead of yielding and letting the tap bore into it.)  I don't like doing that, but it's saved my rear a couple of times, but the smallest bolt I've tried that on had a 5 mm head.  This is an entirely different ball of wax. I am still contemplating disolving the screw with alum, even if that means I have to stick the dial down with double sided tape until I gain the skills to actually replace the screw.
    • Hi Thomas, you should be able to find the right (or on close to beeing) in a Ronda or DCN balance staff catalogue. Cousins uk have those available as a download.
    • Hello everyone. My name is Cees (pronounced "case"). I have been working on watches for a few years now. Got down the rabbit hole when I started watching "how to" videos on watch repair when my watch broke while on holiday. I'm not interested in collecting watches, but purely in the technical side. I love fixing them and also love collecting the tools I need (or might possibly need one day...).
    • The movement is FHF, something like this. But it will not help much to find stem.  Sometimes making one is easier
    • I think they all have their pros and cons, the one I suggested is a threadlock loctite product (Loctite is now owned by Henkel), In general I use the current one that is recommended on their Loctite page (link here)   I use blue (243) for the actual crown the (stick is actually 248 which is the stick version of 243), like I said it is very convenient for using on stems. Blue holds the crown for everyday use, but can be removed if you need to with a little heat. I use the red 277 for things like stem extensions where I have no intention of ever removing it. The purple I don't use (but I have seen some youtubers use it) as I think the blue is removable so why take the risk on a weaker product.   This is interesting, and a useful bit of information to know 🙂
