Thanks for the file provided, I am currently trying to learn how to repair torsion clocks and I need the 400 day clock book as a scanned copy. If you have, please share, I would be very grateful. Thank you
I don't know where you can get a scanned copy. You could always buy the book. I know its expensive but older copies come up a lot on ebay, but if you are going to repair these clocks the newest version is the one to get. You will also need a clock mainspring winder. The 400 day beat setting tool is must. They all run on very little oil.
I do not have the opportunity to buy this book on eBay, since I am in another country, in which this trading platform has not worked for some time, I hope you understand where I am coming from. but I saw a scanned copy of the book, so please, if you have the opportunity and desire to help me find this version of the book. this book will really help me a lot. hope for understanding
to removing the mainspring without any problems with pliers, holding the drum in a hand vice. There are no problems with this, and no additional device is needed. If you want, I can share my know-how on how to remove the spring without any problems.
I also don’t have a tool for setting the rhythm.
Инструмента для задания ритма у меня тоже нет.
I don’t have a tool for setting the rhythm either.
 but you won’t believe it, this can be easily solved with the tools at hand, for example, it’s very convenient to do this with an ordinary scalpel, which I insert into the slots of the adjusting screw and successfully, quite accurately adjust the rhythm, you don’t even need specially sharpened pliers
Hi from your narrative you seem to be au fait with anniversary clocks. I do not know of any scanned copies of the twilligers 400 day manual. They can be bought from Cousins uk (material house)  approx cost £25 .   Or alternatively look at the meadows and Passmore web site.  www.m-p.co.uk as it contains a lot of valuable data on anniversary clocks.
Having looked around the net there are several sites that have a scanned copy but they all require setting up an account the main one being    www.scribid.com
Good time!
I have been repairing watches for a long time, but anniversary watches are not often repaired, so it is important for me to know some parameters of this watch: the length and thickness of the torsion bar, the location of the fork, the article number of spare parts, and more. For this I would like to have a book 400 gay clock.
I can't access www.scribid.com. I described the reason earlier. If anyone has the opportunity to download a scan of this book from this site for me, I would be very grateful. Thank you for your understanding. Best regards.
Removing the mainspring without any problems with pliers, holding the drum in a hand vice. There are no problems with this, and no additional device is needed. If you want, I can share my know-how on how to remove the spring without any problems.
This is bad practice and certainly not recommended. In doing so you are distorting the mainspring. The mainspring should be flat when pulled out with pliers it will not be flat, so when the spring is back in the barrel and wound the spring will be rubbing  the inside which will cause uneven tension which will then effect timekeeping.  The tools I mentioned are a must and they will certainly help you in improving your work.
Cant you obtain the book from other sources such as Amazon comes to mind. What country are you in? There must be book shops in your country. I don't know of any place where the book is in pdf format for free.
https://ru.scribd.com/document/35949737/400-day
Виды перевода
Перевод текстов
русский (определен автоматически)
английский
Исходный текст
.....Заводная пружина должна быть плоской, когда ее вытягивают плоскогубцами.....
немного некорректно сработал перевод,я имел в виду круглогубцы, и пружина остаётся без повреждений. В процессе извлечения пружины, самое сложное удержать в руках барабан,так как он маленького размера, а пружина довольно мощная. Поэтому я использую ручные тиски и зажимаю барабан через прокладку из резины.
.....Zavodnaya pruzhina dolzhna byt' ploskoy, kogda yeye vytyagivayut ploskogubtsami..... nemnogo nekorrektno srabotal perevod,ya imel v vidu kruglogubtsy, i pruzhina ostayotsya bez povrezhdeniy. V protsesse izvlecheniya pruzhiny, samoye slozhnoye uderzhat' v rukakh baraban,tak kak on malen'kogo razmera, a pruzhina dovol'no moshchnaya. Poetomu ya ispol'zuyu ruchnyye tiski i zazhimayu baraban cherez prokladku iz reziny.
Ещё
388 / 5 000
Результаты перевода
Перевод
.....The mainspring should be flat when pulled out with pliers.....
The translation worked a little incorrectly, I meant round nose pliers, and the spring remains undamaged. In the process of removing the spring, the most difficult thing is to hold the drum in your hands, since it is small in size, and the spring is quite powerful. So I use a hand vice and clamp the drum through a rubber spacer.
    • Moebius 9010. A small drop on each end cap jewel (top and bottom)…enough to cover at least half the jewel, but not all the way to the edge. I was conservative.   I like this analogy. And yes, it’s imperfect, because surgeons don’t start with live people. 😂 It’s definitely one of the things I learned with this watch, where I’d fix one issue, but then introduce 1-2 others, often not necessarily getting at the root cause of the “illness.” Well, this watch wasn’t totally destroyed…Unfortunately, I wasn’t able to do enough up-front diagnosis before I started pulling everything apart. This was one major lesson learned to me, but tbh, I don’t think I would have learned it had I not pulled everything apart and seen the interactions of all the different systems (just inside the balance assembly itself!). I have a few other Hamilton 974s that I’ll be able to work on more thoughtfully. I definitely heard your advice, and I think a few others echoed it, but I’m fairly certain I would have introduced more problems by attempting that fix. I don’t have the necessary skill or tools to (1) bend the cock and (2) assess exactly how much it has been bent. I can’t machine a brass plate to attach the cock while bending, I can’t measure the amount of deflection I’ve introduced. And it’s the kind of thing where botching it seemed like it would be irreversible. I’ll attempt to look at the hairspring to see if it’s touching anywhere. The central challenge is that I don’t have a reference point. I don’t have that for end shake or for anything else. I could compare to my ST36, but that seems like an apples-oranges comparison to me (new movement v. 100+ years old). That’s one of the main challenges for me when learning a lot of this stuff – you create reference points yourself! The next thing I was thinking of getting was a JKA Feintaster bench micrometer, tbh. After watching Alex Hamilton measure staffs and pivots, it seemed like it would be a good purchase. They’re just expensive. I’ll need to sell a watch or two first. 🙂  A lathe seems like something where I need to collect more experience before I pick one up. Perhaps you convince me otherwise.
    • Thanks for the reply Andy, I will take a look .
    • I don't think @praezis / Frank actually has a website. If you want his software message him and you'll get the info. I've used Witschi LCD and Vibrograf paper machines since last century, and it really is the best of both worlds. Picks up anything, however dirty (looking at you Witschi), with a readable result.   If you pay for the pro, it tells you exactly where the poise error is for dynamic poising, and it's damn accurate. I can't speak highly enough about this software. Some mics don't work, some do, you might have to solder something, but in all the above Frank can help with a solution. And it's unbelievably affordable.
    • Well, as I have said not once, for the beginners in watchmaking, the hairspring, especially when there is overcoil, is the source of the most of the problems. This is the case here too. The end shake... I told You to regulate it by bending the cock. If it was done, then would be no wondering if the shim is seated correctly every time. You still have to understand how much end shake is normal and correct. One exercise for this purpose:  remove the hairspring from balance. Put the balance in the movement with the cock. Use thin sharp pointed tweezers to grasp the balance staff  where the hairspring collet seats and try to move the staff up/down. The amount of movement should be more or less as much as in escape wheel or pallet fork arbor. In the same time You will see how easy the balance rotates when it is free and without hairspring. Moving the balance up/down by holding it by the rim is not the same, as it forces it to tilt and some shaking may be result of the radial free play of the pivots in the  bearings even if there is no endshake at all. Of course, You can grasp the roller too. You can also grasp the rim, but observe the staff movement, not the rim shake. One should be able to check and say if there is end shake and if it is normal without hesitation, no matter if the movements works well or not at all, and not to wonder if the reason for the not normal working is endshake. Now about the hairspring. You spring is touching somewhere. The fact that this slight lifting of the stud changed the situation proves it. The spring probably touches the arms of the balance, but You are the one that can look at the spring, so it is up to You only to find where it is touching. The spring should be parallel to the plane of balance and thus on equal distances from the cock  or from the balance arms in every position of the balance when it rotates. The coils of the spring must not touch each other. The overcoil also should be parallel and not touching the cock. The spring should not touch (be on some distance from) the regulator pins or the stud bottom. All this must be true also in DU position, not only in DD.  This is achieved by slight bending and twisting close to the stud  or of the overcoil.
