DIY Screw polisher.
Inspired by Alex Hamilton, I have made my own screw head polisher. Less than £4 in parts. I hour to make. Chuffed.
Additional photograph information
Bottom nuts are tightened to make a solid base.  Nuts below and above wood are to make the level set when using the polishing base. I will get a small picture frame with glass to insert the polishing paper. The screws can be altered to accommodate. I can now polish to 1 micron.
I piece of wood 2" x 2 1/4". 2 x M4-30mm bolts. 6 nuts. 1 pin vice from set of 4.
Edited by rossjackson01
More information
  • Like 12
2 hours ago, mikepilk said:
Nice work Ross, but is it solid enough to work properly
Well, first screw would be cosmonaut 😛, but please mike don't tell Ross I said that.
 .... we await the first test.
Wise idea.
  • Haha 2
Have a look
Watches Repair Grinding tools for repairing watches Polishing screws watch clip large steel wheel - AliExpress
https://www.aliexpress.com/item/1005006323971307.html?spm=a2g0o.productlist.main.1.222eNcXxNcXx7O&algo_pvid=9dbf666f-da7d-478b-aeec-3ccf26ccc021&algo_exp_id=9dbf666f-da7d-478b-aeec-3ccf26ccc021-0&pdp_npi=4%40dis!GBP!34.06!28.95!!!303.26!257.77!%402103890917122601452468668eed45!12000037037463356!sea!UK!4431570049!&curPageLogUid=Ap2YMIcipYZ9&utparam-url=scene%3Asearch|query_from%3A
Click where is says . Colour tool board right image.  Full set of tools, for this item
This is £132 plus 20% VAT  plus postage  = £170.
Has ten different pin vice holders. Mine holds any size of Watch screw
Charging £28 plus Vat plus delivery = $40  just for the paper holder
Mine works well. Very solid
Spelling, Grammar, more information
…the first screw would be a beeping toaster that causes panic in the United States, then a dog screw, then the cosmonaut…
  • Confused 1
23 hours ago, mikepilk said:
Nice work Ross, but is it solid enough to work properly  .... we await the first test.
I have some brass bar left over, I might have a go at one myself.
Yes it is solid. Polishes the screw head well. I am going to attach a flat head (DIY) stump from my staking set into the pin vice, using a larger hole chuck. As Alex's comment, I can then hold any flat item with shellac so that it can be black polished. Not tried that yet, but should be easily possible.
Ross, I have had the idea of getting some dial feet replacements, the ones for the milling tool and supergluing them to small flat parts and fitting them to the tripod for polishing. Then drop them in some acetone (nail varnish remover) to get them apart once the part is polished.
Tom
Tom
Good idea for small items. Alex uses the stump for larger objects. Same principle with shellac though.
I couldn't resist Ross, and have started hacking some brass I have left over from the balance holder. Construction is under way !
What lapping paper do you use ?  Alex uses 6, 3, 1, and 0.5 micron.
Cousins don't have 6 micron, but they have 5 (4500 grit). I have 3000 grit wet and dry, so I'm wondering if I could go from that to 3 micron, 1 micron, and 0.5 micron (is this final one really necessary ?)
I need to find some glass
The hardest thing was finding the parts I knew I wanted, but had no idea what they are called. I found them eventually
Edited by mikepilk
I finished my polisher yesterday, and just tried it out. I'm surprised how easy it is to get a good result - just a couple of minutes. I thought it was going to be more difficult - a nice surprise as most things in watchmaking are harder than you expect.
I bought self adhesive 3M lapping film https://www.cousinsuk.com/product/film-lapping-3m-261x266x , 9, 3 and 1 micron, and stuck it to sheets of glass. The 9 micron is course enough to remove large scratches.
I'm glad I used the M6 thumb screws as the large heads allow for small adjustments.
Edited by mikepilk
  • Like 5
Getting more interesting this post, innit?
Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece.
Paper is from
https://www.ebay.co.uk/itm/234602659940?var=534248554534
I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time.
Ross
    • Drat and double drat i was looking forward to the royalties on that idea.
    • Compression Spring Various Size. This might be helpful. I have watch furniture restorers and how they go about this problem, they inject glue underneath with a syringe and clamp it, leave over night. Next day remove clamp and it smooth. You could use an iron but be careful not to burn the wood.  https://www.ebay.co.uk/itm/265697329513?chn=ps&_ul=GB&var=565484998457&_trkparms=ispr%3D1&amdata=enc%3A1jd_-94ilTHWZLQ3PxHeC1A73&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=565484998457_265697329513&targetid=1647205088320&device=c&mktype=pla&googleloc=1006662&poi=&campaignid=17206177401&mkgroupid=136851690655&rlsatarget=pla-1647205088320&abcId=9300866&merchantid=119334104&gad_source=1&gclid=Cj0KCQjwir2xBhC_ARIsAMTXk849TnBArEYdgv1DpHf_somCZYmB7ViqD3UtvNJJc_dn4kj0AFxBXngaArSAEALw_wcB
    • 🤣 i think your first statement is rather dramatic, but i will take it in good humour.  I think the thread speaks for itself John.  What we are aiming for and when i say we, thats not actually that many that have spoke up. Is to have a back up plan to keep members in touch in case the forum ever disappears. So in essence yes the group has maybe taken on a life of its own and would like to remain together forever ( 🤣 i can also be dramatic )  maybe more members need to give some input of how they feel about it or say they are just not that bothered.  Either way at least the question gets answered. Can i ask what the forum means to you and how you would feel without it ? Thats one answer Rich from one person, without knowing how others feel the thread was just a waste of time. Aw Rich are you saying you'd miss me ? I'm touched 🙂
    • you should go to the European patent office and look up watch patents. I'm guessing it's probably impossible to make anything related to watches without stepping on somebody's patent it's good that they expire with time. They've literally as far as I can tell patented everything and anything. this is why is pointing out their other formulas for the Epilam I'm pretty sure Rolex might have their own formula for instance. somewhere in the universe I was once reading things that were rejected for patents for basically this kind of thing. So yes there is rules on what can and cannot be patented but I'm sure things fall through the cracks.
