I was asked to look at a Sekonda that was running for approx. 8/9 hours & then stopping but would run with again with encouragement. When I opened the watch it was extremely dirty But I noticed that under the mainspring barrel there was wear on the plate. After reassembling the barrel & bridge it was apparent that the barrel bridge hole for the barrel was very badly worn. The answer was to re-bush the hole.
I had some clock bushes & luckily had a bushing that had the correct size hole. The problem was however the plate was only 0.373mm thick so effectively I had to make a bushing that was not much more than a washer.
I turned the bush down on my lathe to a reasonable working thickness & then reamed out the hole for the new bushing (3.00mm).
Then I fitted the bushing using my staking set & tested the hole was correct. After a lot of broaching using a smoothing broach achieved a good fit.
I then removed the new bushing & using a soft piece of wood as a base filled & burnished the bush to the correct thickness.
Then I finally pushed the new bushing in with my staking tool but added for safety some lock tight to it,s edge as it is a very thin bushing. Job done just the watch to re-assemble.
  • Like 6
  On 10/5/2015 at 11:13 AM, oldhippy said:
A very nice bit of work.
Question, Aren't parts available any more for this cal.
Probably but I thought learning how to do this repair useful for watches without readily available spares.
A good point.
Great work clockboy, and also very didactic. Thanks!
( Just a question: would it not be possible to push in the new  bushing with the Seitz tool? )
Edited by GuiBer
    • Project: 1, side project count: 3   next side project will likely be a work holding idea to get some piece just so. This stuff is a never ending source of things to do and entertain us    Tom
    • Please do not file nothing. I have no time this days and am able to write here only in midnight time, so please wait...
    • The project is still alive. The parts are roughed out from ground flat bar stock. But before I can move ahead I decided I needed to replace the spindle bearings of my milling machine. There was too much play on the spindle.. But after diasassembly and measuring the bearing spacers, it turned out that the difference in height was 0,189 mm. Way too much to achieve preload on non-paired bairings. So, the spacers need to be ground to get them to the same height so I can use a paired bearing set. To do that I need my surface grinder up and running and that needed a hydraulics overhaul. And that would be easier if I clean out my parts washer/de-greaser first..😀 So... this is getting to be one of those "I need to fix the machine I need to fix this machine to...." type of situation. Happy as a clam though 😃
    • Have a look at this discussion where I show what I use.
    • Hello fellow watchmakers, I have a question for all of you, especially those who regularly work with the Sellita SW200-1 movement. At my workplace, we mostly handle watches with the SW200-1. As many of you might already know, this movement has a known issue with the ratchet wheel teeth breaking. However, recently, I've observed a noticeable increase in problems like: More frequent ratchet wheel teeth breakage Screws getting loose and falling off Sudden drops in amplitude And other irregular behaviors So here’s my main question: Before doing the final assembly of an SW200-1, what are the mandatory checks I should perform to ensure proper functioning and avoid post-service failures? For example, I already check: Ratchet wheel teeth condition Canon pinion friction Accuracy and amplitude Screw tightness Jewels condition But I’d love to hear from all of you — what other important things do you check during assembly? Any tips, tricks, or personal checklist items would be extremely helpful for me and ot hers working on this movement.
