The Atlas Watch Co. Goliath
Blacklab
Fixing up a friends silver Goliath pocket (big pockets) watch movement signed The Atlas Watch Co. The case & dial were in a bit of a state but have cleaned up nicely (note to self take a before pic in future), the movement is in fine fettle & will be serviced in due course. These are not an uncommon item on fleabay but there's very little info on the net, so I am unable to date it etc. So far I have discovered that the Atlas Watch Co. was registered by Stauffer, Son & Co. in 1892, they were generally used as travel watches & sat inside a silver or wooden case.
The main stumbling points are as follows:
Enamelled dial has a chip at 6 what filler is best for this?
Hairline crack running from 6 to centre. I have been informed that denture cleaner can take care of this, but I am concerned that it may take care of the dial markings as well.
Crystal opening 61.35. Nothing in the pocket watches range, so we are into clocks. The problem being the clock crystals supplied by Cousins are stated as not being particularly accurate on size. Any recommendations.
Sub second hand reqd. size is 0.35 x 9mm. Biggest I can find is 0.25 x 8mm.
And finally missing bow 15mm+ internal diameter with a 9mm opening in solid silver, circular & plain. I cant seem to find any bows other than the oval chrome multipacks.
Any advice & info would be greatly appreciated.
Edited by Blacklab
I will look in my stash tomorrow for the sub second. I purchased a few of the bay some time ago & I may have a spare one. I will also look through my stock of pocket watch crystals.
Hi BL.
Regarding cleaning dirt from the hairline crack, I use neat household bleach on a cotton bud to clean enamel dials and found it works very well. Make sure that you give it a good wash with water to remove all traces of bleach afterwards.
I haven't tried this, but how about touching up the chipped area with Tipp-ex then applying a little lacquer with a very fine paintbrush.
No luck with the crystal also all my spare pocket watch hands are 8mm long but appear to have the correct post size 0.35 (see pic) If this is OK send me a PM with a forwarding address & I will send.
Thanks for the hand CB, arrived in the post yesterday. You are a true gent & scholar.
The crystal turned up Edmund, the 61.5 is a drop in fit (just) so I will probably order a 61.6 to get a heat-shrink fit, as I always find gluing problematic.
@clockboy: what is that tool you are using to measure the inside diameter of the hands? Where could I buy one?
Thank you!
Bogdan
Bergeon 30464
I have found it very useful when adjusting hands to fit. It is also supposed to be Ok for measuring jewels & bushes but I have never tried.
Its been on the back burner for a while but now finished:
..oops, that was the before pic I forgot about (Nurse get my pills). Here's how we're looking now:
I managed to fashion a bow from 3mm sterling silver wire supplied by Cooksongold.com, very good suppliers of findings, bullion, gemstones etc.
Big thanks to:
Clockboy - for the hand, although I used a fettled chrono one in the end. Please PM your address & I will return it.
Edmund - for the lead on the crystal- perfect.
Geo - for the bleach tip. Its worked really well. The hole was filled with Bergeon 1590 white wax.
.............couldn't have done it without your help. Cheers!
Stunning work. There you have another ticking fellow who is going to survive us all.
Did you use any special tools to create the bow? I precisely need to restore my great grandfather-in-law's silver watch, that has a missing bow, so your comments could come very handy.
Edited by Edmund
Big thanks to:
Great result Blacklab really nice looking watch. PS keep the hand in your stock you never know!!!
Very basic work - just bent it around a suitable piece of round steel (a socket set extension in this case) gently tapped with a nylon face hammer, ends cut with wire cutters rotating while gently applying pressure which rounds off the cut & helps in fitting into the stem tube. Silver hardens quite quickly when worked so no further hardening was carried out. The bow is more of a decorative item on this watch, I wouldn't suggest putting a chain on it as it may not hold in place.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
