Hello!
This is my 3rd post and this time I would need help to go on with my project, so thanks in advance:
The 2790 is already serviced with a reasonable performance using. when I was fixing the hands to case the movement I noticed that setting the time required high torque to move the hands. The time-grapher showed about the same performance...
I double checked and noticed that when I take out the pallet fork  the time setting is back to normal (soft). I can't understand the relation between the pallet fork and the time setting...
Additional info:
1. I double checked the calendar mechanism
2. Double checked the remontoir mechanism
3. I can't manually move the wheels when the pallet fork is installed and the balance is out of the movement.
So, it seems that I am doing something wrong and the only thing I notice is that if the balance is installed the watch works but the time setting is too hard. If the pallet fork is not installed I can set the time without a problem... I put back the pallet fork and it ticks when is touched but the hands are again hard to move.
Please let me know if you need any other information.
Thanks for reading my post.
Fernando
Just to be clear, when the watch is assembled and the setting position is stiff, the hands still move, correct?
By removing the pallet fork you allow the train to run freely, so when you put the keyless works in the setting position, the cannon pinion won't slide and  you are turning both the motion works and the train. The 2970 uses a cannon pinion wheel setup like this image.thumb.png.41b328dd4a81378d74b663c5380919da.png
Make sure you've lubricated the contact points between the wheel and pinion.
Hi Fernando,   When the patter fork is installed you cannot move the train  as it’s locked by the pallet. And it yo7 can’t move the train with ths pallet fork a balance you have a problem. With the train installed and a couple of turn# on the mainspring the train should move freely. Ok can only suggest dismantling the watch and reassembling it again checking each stage as you complete it
start with mainspring and train wheels, always checking the train freedom.  When assembling the keyless work make sure the right screws are in the right places.   If you look on cousins uk web site and look in document down loads you 2ill be able to find and print the technical sheet for this movement eta 2790.
Hi! My bad. I meant to say that when the pallet fork is installed I cant move the wheels "using the crown in the setting position" Really in truly my number 3 was redundant and badly written (trying to explain myself went all wrong).
I dismantling partially the watch (calendar, remontoir, Balance and Pallet fork). I think I would need to go that way...
Thanks for your comments...
1 hour ago, eccentric59 said:
Just to be clear, when the watch is assembled and the setting position is stiff, the hands still move, correct? (Yes, but slowly and I need to apply high torque to the crown.)
By removing the pallet fork you allow the train to run freely, so when you put the keyless works in the setting position, the cannon pinion won't slide (this sentence is making me think as you can't imagine!!!) and  you are turning both the motion works and the train. The 2970 uses a cannon pinion wheel setup like this image.thumb.png.41b328dd4a81378d74b663c5380919da.png
Make sure you've lubricated the contact points between the wheel and pinion. Ups! I think here it is the root of my problem... (1. I did not oil where you mention!!!!!. 2. I took this setting and it seems or feels to me that the pinion does not rotate within the wheel and it should. )
This is my second ETA and I never stopped to think on how this setting works. I really appreciate your comments
Thanks Fernando
Hi Fernando, read carefully what @eccentric59 wrote, it is the key to You problem. Lubricate the cannon pinion. Take care to understand what is it's function. When You set time, the train doesn't move, but only the cannon pinion moves. Put hte lever back in it's place, it has nothing to do with time setting
Yes. I understand (now). I regret to say that I am servicing watches without fulling understanding the cannon pinion function in relation with setting the time  (and many other theory aspects of the orology!!!). If is too tight the hands won't move and on the contrary. If the pallet fork is not installed the train of wheels will spin freely and if the remontoir is on the setting position the motion wheels will also move.
I will use HP 1300 for the cannon pinion setting.
I am happy and grateful and of course I will report back as soon as I can.
Thanks
Hi Hiaz,
I see you didn't get this link usually given to new members by oldhippy, here , useful stuff.
704789946_TZIllustratedGlossary(2).pdf
4.2 MB
These are the places where I oiled with HP 1300...
I can see that the cannon pinion is moving as it should once I installed the pallet fork. I created a small video but was not able to upload it. It is a mov file type.
I need now to source a GR4014X mainspring, a stop ever #9433 and both calendar disc as the days/dates are peeling out...
This is the mido watch which holds the ETA Movement....
I just want to thanks all of you guys for your help, specially @eccentric59 who nailed it!
So, I would consider this case as closed unless of course any question from any of you...
Best regards
Fernando
8 hours ago, Nucejoe said:
Hi Hiaz,
4.2 MB
I could not download the file... I will tray to located. Many thanks.
I just coppied this from a old post of  @oldhippy .
Hang on , he'd be there in a sec.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
