Low Amplitude from Ultrasonic cleaning?
It seems to depress. And on something like an omega its a really simple job, just about to try with the button in as apposed to set. So frustrating as I actually have the right crown! And in all other respects the watch is a great example!, not sure its ever seen intervention, but I guess it must have because it has a new unsigned) crown! Prize for the first person who provides the solution!! I have added more images, sorry for the quality, best Samsung can manage in Macro mode.
@VWatchie does make available a lot of stuff previously using one drive so maybe he can have a look. It could easily be something as simple as default permissions have changed with a routine update. Tom
Hi going by the pictures you will have to remove the bezel and glass. The bezel needs to be lifted either with or without the glass depending on construction, I the bezel comes away without the glass you will need a tool to lift the glass to remove the movement. -
Hi welcome to the for um, that’s not a bad average, attached a little reading to assist. TZIllustratedGlossary.pdf TM 9-1575.pdf
