Omega cal. 625 crown wheel screw
It is possible to true the pearl basket to run better takes a good hour of filing though. -
Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp. -
I agree, very minimalist dial, but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
This is such an odd Bulova. Off of the top of my head the only other mechanical Bulova that I can think of that has the 'Bulova' logo as an hour marker is the Golden Clipper 'J' (there must be others), one of my favorite dials. And then it has a solitary diamond, which is not unusual with Bulova, but paired with the 'Bulova' hour marker, that only leaves two quarter hour markers, and I can't think of another Bulova that has only two hour markers like that. You do you Bulova, no conformity here!
1973 Bulova Diamond Excellency Q. 11 AN mov't manual wind. Love the UFO look of this one. Not sure the size of the diamond but looking around for an advertisement to see if it is.listed....strap is not original but the buckle is signed along with the crown. In excellent condition.
