Looking for advice on removing the glass and bezel
The mineral crystal on this "Régulateur" watch has a scratch just before 8 o'clock. The scratch looks worse in real life than in the pictures. I'd like to replace the crystal or perhaps try to polish it out. Also, I'd like to polish the case but don't want to risk polishing the bezel. So, looking for advice on how to safely remove the crystal and bezel. I think the crystal can be pressed out from the inside but I have no idea if the bezel can be removed or not and I don't want to damage things trying. I always feel insecure when handling crystals and cases 🫤 I hope the following pictures will be helpful!
21 minutes ago, RichardHarris123 said:
I don't know for sure but on a similar looking watch, the bezel unscrewed. I believe a custom made die was made to remove it.
I'll try to unscrew it by hand but if it doesn't budge applying medium force, I won't force it. Any other ideas?
When I run up against this kind of situation, I use a razor blade and gently pry up to see if there is any movement.  If not, I assume it is screwed on.
I realize this may not help you, but when I have something like this that is hard to unscrew, I will often design a tool and print it in PLA on my 3D printer.  PLA will not damage the watch.
You may also consider the superglue/nut technique.  Glue the nut on the glass and see if you can unscrew it.
These situations are always tricky...and sometimes scary.
Sometimes there is a small "lip" in the case where you can use a case tool to open. It almost looks like I see one in your last photo. (It could be the camera angle.) I can understand being careful with this watch.
Edited by JackH
What sort of watch is this ? Modern quartz fashion type of watch ?
2 hours ago, JackH said:
Sometimes there is a small "lip" in the case where you can use a case tool to open. It almost looks like I see one in you last photo. (It could be the camera angle.) I can understand being careful with this watch.
Might be my imagination as well there looks like a filed in notch next to the lugs. You will know for sure watchie, i would try a sticky ball on the glass first to see if you can get some rotation either way, very unlikely you will damage with that amount of force. Place a piece of masking tape over the edge of the bezel onto the case as an indication of movement, the tape will wrinkle or tear if anything is budging.
I would say it will comes off like a Rolex bezel. Don't use a four jaw bezel removing tool. as they are crap and I don't know any decent watchmaker who uses them. They use a Stanley knife and brass hammer for really awkward bezels. A lot of the time a Stanley knife going slow along the circumference of the bezel will do it. Here's a link to my cloud storage where a video of removing a Rolex bezel. I'm not saying it is the same, as I haven't got the case in my hand, so on on your head be it. Use really thick plastic sheet for protection. Not jiffy bag stuff that you use to remove hands!
https://drive.google.com/file/d/1dEmHz_9pLCPeMukfk1IMFL8J0Ymju7S2/view?usp=sharing
Just had the same problem with my Seiko 7S26-0480F. I tried my special tool with 4 blades that inserted into the bezel gap. No matter much pressure I made, I could not remove it. I then used the hand press tool. Large plastic part underneath to support the case base and a smaller disc on inside the case and onto the crystal. Increase in pressure. A loud 'crack'. Top press to bottom. Bezel and crystal removed. Phew!
So much for the specialised remover. Back to basics for me.
Edited by rossjackson01
More information
Thanks for all the input guys, much appreciated! I'll consider it and see what I do.
🤣 That ugly, uhu? It houses a Peseux cal. 7040 and the dial has a classic regulator watch layout (except for perhaps the date hand). It is perhaps not haute horlogerie, and I suspect that the dial is made of some sort of plastic material. Nevertheless, I sort of like it.
I suspected it because I had no luck with mine! 😯
I just watched it and O.M.G! 😆 Were you able to put it back on? If so, what did you use to press it on?
Edited by VWatchie
🙂 apologies watchie no fashion watch was the wrong term, it looks modern, the 7040 is an old movement design.  I was looking for a stem for somebody yesterday for that calibre.  No i do like it, the dial has a clincal look to it though, I'd like to know if it is enamel or ceramic maybe. I also like date pointers, i have 2 Oris that have it.
Haha that looks appropriately vicious.  I'd expect a stanley knife to cut straight through the sheet so i imagine the blade has been dulled down. If i were to attempt this i would take out the stem first and try to stay away from the lugs if at all possible.  You may have to resort to something like this.
I used a Robur press and dies to fit the bezel back on.
I must admit, it does look pretty vicious, but very effective. You can see why a four jaw bezel removal tool is as much use as a chocolate tea-pot! Taking out the stem is a good idea if you're doing this for the first time, as you don't want to slip. The lugs are never touched when working around the bezel, as you only need to flex the blade a little at a time so as not to touch or damage the lugs
14 hours ago, RichardHarris123 said:
And hopefully remove the balance first!!!? Would it be better to remove the blade so the hammer action was perpendicular compared to transgential? A genuine question.
Yes the balance was removed first. Don't use the blade on its own because it is only thin and when hitting it you want it to remain as flat to the work as possible without the blade moving about and risking damaging the case and bezel. The Stanley tool is the best thing to hit as there is more stability. Don't worry about the hammer not being perpendicular, as the end of the Stanley tool is resting on the bench. Most watchmakers use a blade to remove this type of bezel, although this was quite a tough one to remove. The trick is be deliberate in your actions. As soon as you are tentative, that's when things go South very quickly, in my experience.
37 minutes ago, Kalanag said:
Last time I had a similar bezel it was screwed on. For opening I used a 3D printed tool and double sided adhesive tape to get more grip at the bezel.
chronoswiss-kairos-how-to-get-the-movement-through-the-front
Zwischenablage02.jpeg.eefc370598b1478e068784d0bc0ca0f9.jpegIMG_8162.thumb.jpeg.73cddfb521608da3c6b14b60fe9e5111.jpeg
That reminds me of the big plumbing nuts that i use for wastepipes
Very much like the hacking knives i use for woodwork and deglazing frames. Same principle of use, the blades mushroom over with impact above the cutting edge eventually. Stanley blades can be quite brittle though, I'd suggest a brass hammer like you're using here Jon, rawhide would be good if one that small is available to buy. I get the technique entirely which is why i said appropriately vicious 🤪
13 minutes ago, RichardHarris123 said:
Oops, yes typo again.
Haha, i nearly spat my tea out when i first read it.
Edited by Neverenoughwatches
Just now, RichardHarris123 said:
Bloody hell, I  hope your watch tools don't look like your hacking knives.  Hehe.  Brings back memories, I used to do a lot of glazing.
I rarely use them now, this picture was pulled from ebay. A fantastically simple very efficient tool, they were a permanent fixture on my tool belt.
How could you tell it was screwed on?
Tried that but it won't budge one bit, but it was a very good idea!
On 2/2/2024 at 10:34 AM, Malocchio said:
I have this. Great if the bezel is so stuck that a knife is no good. Kind of a spring loaded hammer.
That's an interesting idea. I'll give it a try and see if something happens. If the bezel is screwed on I guess that the worst that can happen is... nothing, no?
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
