Hi, from S.E. Texas
I'm slowly getting into doing more and more things on my watches and I thought I'd come here to pick up some knowledge.  I made a list of things I've done so far:
1) Adjusting bracelet length
2) Replacing spring pins
3) Removing/replacing case back
4) Polishing scratches from crystal
5) Removing movement
6) Removing movement ring
7) Removing crown and stem
8. Removing/reinstalling hands
9) Removing dial
10) Removing day wheel
11) Removing date wheel
12) Inspecting/replacing plastic gears involved in day/date change
13) Removing cannon pinion
14) Removing rotor
15) Replacing mainspring barrel (haven't reinstalled yet, waiting for part)
16) Simple regulating
I've had some casualties!  In particular I mangled a mainspring while doing some of the above.
Hello Rob,
If I may play coaching you, swimming trunk or bare a**  , just jump in.
Get you couple of scrap movements, preferably of same caliber, and tear one of  them suckers down/ reassemble/ tear down again,  doing this,   I promise you wouldn't trigger world war 3  .
We all have broken parts, so will you.
Welcome here and good luck pal.
12 minutes ago, RobBrandywine said:
Thanks for the welcomes.  I actually meant to say I mangled a hairspring, not a mainspring.  Much more serious!
Hi Rob welcome fella. Joe's advice is bang imo. Get watches of little value but complete to begin learning with. Less stressful knowing that mistakes are not so painful. Mangled mainsprings are non repairable whereas mangled hairsprings can be. The possibility of replacing a mainspring though is higher.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
