Static vs dynamic poising
That's great Col, i firmly believe once you have gained some knowledge you just have to jump in and crack on. -
By Terrinecold · Posted
Hello, I have started learning to work on watches a week ago on an ST36. I have the technical datasheet for the ETA 6497 and I read everywhere that one is a clone of the other. That surprises me a bit because the bridge structure is clearly completely different (one barrel bridge which does not cover the central wheel, one gear train bridge for the center, second and third wheel, one cock for the escapement. So what makes it a clone? Is it the arrangement of the main plate and things like the keyless works?
