New member from Northamptonshire 🏴
But he tells that the micrometer cap doesn't screw into the spindle. How can the spring push the spindle up if there's nothing to grip? There is a screw visible on top of the micrometer cap so should it be able to screw into the spindle? I'm feeling really dumb now. Does anyone manufacture that cap as an aftermarket item? Might be worth investing.
Sorry, I should have been a bit clearer. I have had this watch for a long time and it previously stopped due to an obstruction in the train. Never had any issues with the cannon pinion until after the service.
ive got a 3220 dd module here that i go back to every now and then an it never works correctly , massive pain as i love the watch i that needs it!
