Bulova 11AF Will Not Run
I really like these adjustable winders, in particular the multiple choice of arbor sizes within the same winding nut. Mine are the Star brand but that is more than likely just a retail name. If you find the spring ends snapping from slot to slot then just release some of the tension, let the spring unwind a little and then feed the end in by hand. A drop of oil on the insides of the prongs and ease off the edges of them makes them less harsh, but no personally i would leave the arbor hooks alone, try backing them out where the spring isn't so tight as it is at the very end, I've had the hooks release completely this way. -
By LittleWatchShop · Posted
you can push out the old pins and replace with new pins on "most" arbors. I have seen a few where they were "pinched" rather than pinned. Also, you can push out the entire arbor from the knurled knob and turn a new arbor, pin it to your desire. Very flexible...IF you have a lathe. -
No, not handed. That's why I bought it I think. I assumed I would work on more Japanese movements with left wound springs, but that hasn't turned out to be the case. I think the only left wound movements I have ever done are HMT (Citizen). I've considered filing down the arbor pins a bit but don't want to ruin it. Occasionally I see a set of the K&D arbors alone show up for sale and maybe I should buy some to modify.
Quite a few parts are discontinued or are restricted items. Unfortunately you'll probably have to pay a ridiculous price or make one.
