Good day one and all.
I'm new to watch/clock repairs but have the patience and determination to learn new skills as well as being good at fixing things.
I have recently acquired an old Smiths Enfield pendulum with gong clock movement which runs only when tilted at a slight angle.
I stripped it down and rebuilt/oiled it following a video on YouTube from Scotties clock world.
it wasn't running before but does now although only when I tilt it a few degrees to the side, It's currently fitted inside an old Smiths clock case but when mounted square it ticks a few seconds then stops, if I lift one side of the clock case up in this instance the right side when looking at the rear of the movement it ticks and works overnight and I believe at the moment it still is ticking, I'm not at home to check but it was fully wound yesterday when I put it in the case and this morning when I left home for work..
The only adjustments I've made is to the pendulum length by the screw on the shaft.
The attached picture isn't my movement but the same type.
Any suggestions, I guess it could be something simple.
Thanks in advance, Andy
Hi. The escapement is out of beat . Untill the movement is level it won’t  run.  Tilt thr clock from either side untill you get an even tick…tock. Now the hard part,  the escapement bridge will have to be adjusted until it locks the pallet/anchor correctly.  First remove the movement from the case and make a stand to fit it on. Next check the movement is level (spirit level). You can get little ones. Now we have the movement mounted level. Move the pendulum left to right can you see it releasing the escape wheel in not move the bridge up or down on which ever side does not lock properly, once done a couple of turns on the spring fit pendulum and re try running the clock, if not go through the adjustments again. It can be a fiddly job but requires patience. Come back to us with the results good or bad for more information.  At this point do NOT bend anything.
See this video.
You have to adjust the tail of the anchour in a manner that the clock is level and in the same time the beat is even. This has nothing to do with leveling the movement, as it can stay tilted in the case and this is not important.
Hi. Yes of course the movement will work not on the level if chocked up or the pendulum leader is bent or adjusted to do so. M any mantle pieces ,shelves sideboards where the clock# resides are no level so some small adjustment is needed like two pennies under one side. The reason for setting it up level out of the case is that once set up and running ok you can observe the escapement and make sure the pallets are locking ok under running conditions. Once all is ok then case the clock up and adjust as required by moving the pendulum leader to maintain a steady beat. Adjusting a clock to overcome the intolerance due to being not level is the correct procedure. Make sure the movement works on the bench first and is level.   Anniversary clocks have to be level or nothing works so get used to setting them up correctly. I it has been dismantled and the escapement cock/bridge removed the pallet depth will have to be reset and can only be done on the bench.
On these clocks the pallets are mounted on their arbor with a friction fit, and beat error is adjusted by carefully rotating the pallets around the arbor against the friction.
To do this place the clock on a level surface and set it running. Observe the pendulum and listen to the ticking. If it's out of beat then the tick on one side of the swing will be longer than the tick on the other, this is because the pallet is engaging too deeply with the escape wheel on that side. Once you have determined which side of the swing has the longer tick, gently push the pendulum across to that side until you feel a stop. This is when the pallet is fully engaged in the escape wheel and can't go any deeper. Now gently but firmly push a little more. This causes the pallet arbor to rotate slightly in the anchor so that when the pendulum is released it will have slightly less engagement on that side than before. Test the pendulum again and you should find that the ticking is less uneven. You may need to do this several times, pushing the pendulum against the stop on the longer tick side of its swing until you get it right and the ticks are even. It's very easy to go slightly too far so you may have to adjust in the other direction as well.
If the clock is intended to live on a surface that isn't level then all you need to do is set the beat up on a test surface that has the same slope as the intended location for the clock. That way even though the clock isn't level it will still be in beat. Obviously the severity of the slope that you can accommodate with this procedure is limited by how much free swing the pendulum has.
I first got this procedure from instructions on a factory printed label stuck on the inside of the door of a Smiths clock, so at one time it was part of the set up instructions Smiths provided for their clocks, and I have used it on many Smiths clocks since. I can't comment on how it applies to other makes. Also I would say that, as with most things horology, if it requires anything more that gentle force there is probably something else amiss and further investigation is needed to prevent inadvertent damage.
Thanks for the advice, I'll give this a go in the coming week when I get a chance and update with the results. So far it has been running for a couple of days with what sounds like an even tick, I don't have the hands on it at present, I'm running it to see if it keeps going consistently before I put it all together.
It just needs to be put in beat. Make sure the suspension spring is in good condition, any kink in it then it needs to be replaced. I have watched many videos Scotties clock world. He is nothing but a cowboy I cringe at many thinks he  does in his videos.
Hi, I also had these problems at the beginning of fixing these types of clocks. This video helped me understand what the problem was and how to fix it.
As always, you have to take things on YouTube with caution.
I hope it helps you.
20 hours ago, watchweasol said:
 ...I it has been dismantled and the escapement cock/bridge removed the pallet depth will have to be reset and can only be done on the bench.
Actually, wery few people, even watchmakers, know how to do this and what it affects at all. This is because the VERGE watches and clocks went out of service very long time ago, and very few people still working on them. The Schvartzwald escapement is simplified variation of the verge escapement and it acts and regulates the same way.
I have written an article on how to do this here. Of course, it is in russian. Use google autotranslate, if needed I will try to explain in english, but it is not my language and not so easy for me to do. The main thing when adjusting old clocks where the escapement has wear is to make the depth as deep as possible in order to obtain some normal isochronism. If the depth is not enough, the clock will run faster than the pendulum own osillations period, and will work faster when fully wound and slow down in the period between windings
Edited by nevenbekriev
One of the ways of sorting out if the pallets are worn is to re-face them. Some advice is getting out of hand with this type of clock movement. Providing the escape wheel teeth and pallets are fine you just adjust the pallet cock so the escape is not to shallow or to deep, to deep and it wont work, to shallow and the pendulum will hardy swing. It is also good practice to mark around the pallet cock before removing.
Edited by oldhippy
Hi I think it all depends on whether the cock/bridge was removed for cleaning. If not the hole pegged it should fit right on with the plate, still needs checking . If it came off the plate without marking you then have the problem of adjustment and all it entails. But as OldHippy has said is essentially what’s required to achieve a running clock.
So I have it working on a level surface and it’s ticking along nicely if you pardon the pun. Thanks for all advice given.
I had to disassemble the movement after knocking the clock over accidentally and bent the arm on which the pendulum hangs.
Also when assembling the gong mechanism which I hadn’t yet done when posting before, I discovered the arbour on which the hammer sits was in the wrong holes, I can’t think why there are two matching holes on both plates in which this arbour perfectly fits and are about 10mm apart from each other. I didn’t realise until I tried testing the gong and the star wheel failed to meet the tab on the gong arbour.
After installing that correctly it’s working but it seems to chime a few minutes before the hour which I need to investigate
Anyway it seems to be working quite well, I need to keep an eye on the accuracy and adjust as required then I will put it back in the case.
Hi if you wish it to cvhime dead on the hour you can adjust the minute hand on its boss by fitting it on a square file / bar and moving the hand relative to the boss. Inch avhieved re tighten the boss to the hand, not overly tight but tight enough to prevent slippage.
Hi all.
Well It's been over a week and using the original hands which came with the movement it chimes on the half and full hour, I will try watchweasols method to adjust the spare hands when I get around to it.
I've put it back in the case and it's running consistently, I'm still trying to get it to run accurately. To start it was losing nearly two hours a day, slowly with tweaks to the pendulum length it seems to be getting better but still slow over a full day.
Listening to it tick, when it was losing around an hour a day, counting the ticks it seemed to have a beat of around 88 bpm, it's running slow at that point so should have a higher count by my reckoning, is there a figure I should be aiming for in regards to this movement to be accurate?
I have had a good look at the first photo and if that is your clock I can see why you are having trouble getting it to keep time. The leader is the wrong one for this movement. The crutch of the pendulum should be about half way in the hole of the leader, yours is resting on the bottom of the leader, it should be free. That is also why the suspension spring is long, a shorter one and the leader would not fit. If you look at where I have ringed you will see what I mean.
Here is a picture of my movement. I’ve taken the gong out of action for the time being which is why the hammer is not shown and the coil is low down, also allows a better view of the movement rear. The red arrow is a reminder to myself which hole not to use for the gong hammer arbour during reassembly. The pendulum was bought separately from the movement.
Thank you for the clarification. Can you advise what I should be looking for in regards to the correct leader?
Thanks
The leader came with the movement, I just bought the pendulum afterwards.
Hi there,
The pendulun and the leader are OK.
You clock has to go with about 172.41 BPM (according to my calcullations based on a picture of a stripped down movement where I could count the teeth of the wheels). You say it is going with about 88, which should actually be 196.  This means the clock now actually goes faster than needed. What You should look at is the central wheel and the shaft on which the minute hand sits. There is clutch there with big 5-leaf spring. I bet it is sliping and the shaft turns slowlier than the wheel. If the movement is out of the case, put a mark with marker on the wheel to point the place under the hand, then observe if the hand will fall behind the mark.
2 hours ago, nevenbekriev said:
Hi there,
The leader is not the correct one.
Hi. Just because the leader came with the movement doesn’t mean it’s the correct one. I have an Enfield such as yours , and as stated by Old Hippy the crutch is midway in the leader slot, so until that’s sorted any other adjustments etc will cause problems. Fix the leader crutch as it should be then start from scratch knowing that the clock conforms to spec.
Dear boys, the crutch is a little bent down, that's all. This is not important, as the clock works and do not stop. The whole lenght of the pendulum is correct and the frequency is less ot much correct too. But the clock is slow 1-2 hours/day. Then, leave the pendulum alone and search for the real reason...
nevenbekriev, thanks for your input but you are clearly wrong. Just look at my post where I highlighted the problem and you can see I'm right. I was a clock maker for around 30 years working on high grade clocks and not just repairing but restoring and making the parts. I think I know what I'm talking about. Have a Happy Christmas.
OK, then please, answer this question: Is it possible to do something with the pendulum or leader or suspension spring or whatever what the high of this wooden clock case itself alows that will bring to 2hours/day dalay??? Or, may be the movement is from longer case?
For the record, I too restore antique clocks and make parts for them. From 40 years, with breaks.
Hi.   You can make bits and bodge clocks to make them work even if out of manufacturers specifications, but it’s best to get the clock back into spec with the correct parts. Once that’s done then investigate the problem. Once found you are sure in the knowledge it’s as was when built. Bodging is not the way to proceed.  The only five star spring clutch I have had in fifty years that failed was because someone had been working on it and ruined it.
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
