Waiting For A Movement?
I wonder how you do when you adjust a newly serviced movement? I had a ETA 2781 service yesterday . Adjusted it to almost perfect beat and +1 sec a day . But now when i should send it away to the owner it didn't run so nice . I was about to send it to the owner . So i set it up in my Timegrapher. And now it run 1,1 beat error but almost the same deviation . I adjusted it again to run good
How do you  do? Do you check the watch after a couple of days .And readjust it ?
 It makes me feel bad ? I am so afraid the owner will think i am doing a bad job. Almost a litte OCD  :D
Edited by rogart63
Hi Roger, that's exactly what I do. I either wear it or have it running on my watch winder for a couple of days.
I do the same as Geo I wear it for a few days. However this is not always practical especially if the band is too small. I now look at all angles i.e. DU/DD etc etc & make sure I have a really good average with priority being the way the watch will normally be worn which is Dial Up or Crown Down. The watch winder is the answer but it's cost over how many watches you are going to repair for customers.
I think it's pretty standard practice to run a freshly serviced movement for two or three days before making any final adjustments. It gives time for the mainspring to cycle through at least one full wind and for everything to settle down. It also allows for any faults in calendar works etc to show up and for everything else to settle down.
Did you adjust the movement before you put it back in the case?
Had to because it was a front loader .On other watches i do it after i mounted it in the case .Adjust it to run okey and then do the final adjustment in the case . Always tricky with front loader .
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
