Seiko 7S26B rotor bearing adjustment?
Hi All,
I have a Seiko 7S26B who’s rotor bearing could do with a little adjustment, tightening up. Is this the type of bearing that can be gently adjusted in a Horia tool? I’ve never done this. If it is possible, any tips or tricks? Can it be done in situ in the rotor? Any help greatly received.
cheers, B.
From the looks of it should be adjustable.
 Press on the washer thats underside of the bearing ( fig 2 )  to move it until you feel it ( the washer) doesn't want to move any deeper.
It can be done in situ
Press carefully:    DO NOT PUNCH
Good luck
Edited by Nucejoe
Good luck
Thanks Joe!
 In fig 2 you can see the washer which is press fitted, press it back with .01 mm tolorance  to the balls of the bearing, obviously theres a risk of damaging the balls in the bearing or deform the washer if you punch.
Support the other side of the bearing on a anvil.
Thanks Joe!
I think this is the one (Omega Speedmaster Part 1):
9 hours ago, nevenbekriev said:
And, in fact, did anyone successfull adjustment?
To be fair he does provide a disclaimer that this solution is only successful when fixing a small problem with the bearing
Someone, maybe it was Spencer Klein(?), has had some success with hammer time but it doesn't sound like a very permanent solution. Perhaps if spares are really non existent. I bet Spencer has a ton of spares (of every single part).
Edited by Malocchio
On 10/18/2023 at 8:28 PM, nevenbekriev said:
And, in fact, did anyone successfull adjustment?  No?
Because the bearing is not adjustable...
There is a way to adjust it, but it must be taken apart and one of the cones must be grinded in order to go further against the other cone and thus to reduce free play.
Pictures here
Hi, I didn’t have any success. I adjusted it .01mm at a time a few times and no difference, so didn’t want to go much further. I think it only works with some bearings as someone else said. Thanks guys for your inputs. Ta. B.
How exactly You did the adjustment? Did You grind the correct side of the cone? On the picture, the cone is put on a diamond file in a way that can be pressed with finger and slided on the file and thus grinded as it should. No way to bring the cones of the bearing closer to each other and no effect at all to happen.
Just to clarify, this is not the hammer time video, this video is specifically referring to the repair of rotor bearings and he uses a completely different technique. It's worth a try before investing time and effort in a new part as you have nothing to lose.
Actually, my question was a retorical one. I knew the answer, that's why I asked. But, If You read my post, the one that You quoted, to the end, You will find that I gave there link to a discussion in another forum (Bulgarian), where I have shown solution for the problem with restoringing this bearings. There are photos there, that show the real process of restoring the bearing.
Edited by nevenbekriev
On 9/26/2023 at 6:52 PM, Boydie said:
Hi All,
cheers, B.
Adjusting the rotor bearing on a Seiko 7S26B is not recommended using a Horia tool or in situ within the rotor.
Hi All,
I have a Seiko 7S26B who’s roller bearing could do with a little adjustment, tightening up. Is this the type of bearing that can be gently adjusted in a Horia tool? I’ve never done this. If it is possible, any tips or tricks? Can it be done in situ in the rotor? Any help greatly received.
cheers, B.
However, if you're determined to try it yourself, I strongly advise against using a Horia tool. It is not the right tool for this job and could cause more harm than good. Instead, you would need specialized press tools and replacement bearings for your specific 7S26B caliber. Or you can check more bearings info at https://www.tradebearings.com/
Edited by jannickz
I will try again, for the last time.
To restore the bearing, You first have to dismantle it, like this.
Then, one must grind this surface a little, in order to allow two cones of the internal ring to come closer to each other
The grinding is done this way, pressing the ring by finger and moving it on grinding surface - in this case a diamond file
Then assembling the bearing and test of the free play, if needed - repeat untill free play gets minimal.
No adjustment only by pressing is possible, this is a silly thought.
Thanks for the explanation, can you please advise the best way to dismantle the bearing, is there a trick to getting it apart without damaging it?
Yes, the old like 7009 are just pressed and and only pushing of the downside part thru the hole of top part, untill the rotor is supported above proper hole is needed. The newer are riveted, so first some drilling of the riveted part is needed. No riveting is needed after all is done, as the screw holds the both parts together well pressed
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
