Folks I have to say I'm enjoying my interactions with you all regarding watches and techniques. I don't know how you all contract for marketing stuff but I have to say it's interesting on the Brazilian end, screen shot attached. Not complaining.
Expand
Yes the advertising isn't it interesting. Here's what I found if something visually well if you find something visually appealing you should click on the advertising and go there. Look at some items doesn't matter whether you want to purchase the items Or not if you find it visually appealing then the advertising will think that that's something that you need to purchase and you will be rewarded by seeing visually appealing advertising.
Unfortunately for me currently the advertising thinks I should go look at eBay. So I'm currently not seeing anything that's visually pretty.
John thanks for the explanation, I have to admit that a) i find good looking women attractive and b) I'm starting to spend more time on eBay. I'll let you know if the advertising changes over time cheers...Jules
  On 9/11/2023 at 4:34 PM, Juleswatch said:
John somethings gone wrong at my end - I now have eBay advertising instead of the girls
Expand
Yes I notice I still have eBay. On the other hand at least it is not watches yes I know we like watches but sometimes when there is such an overload of watches it's hard to figure out where the discussion is amongst the advertising.
  On 9/11/2023 at 6:01 PM, RichardHarris123 said:
How disappointing, maybe you should look up lingerie on ebay.
Expand
I was going to do the experiment later in the day but off to eBay for a few minutes it looks like I haven't been there so long I had the login. Now that I'm in let's look at women's underwear. Then eBay made suggestions of? No I'm not going to give you images but the definition of women's undergarments has an amusing well that just isn't very much covering down there. But I see eBay is making lots and lots of suggestions of and let's see if it has any changing on my eBay choices on this website. It probably won't happen instantly I'll let you know if anything changes.
Although? I wonder if it would've been better to click on the eBay advertising here and then go look at something okay I'll just leave what I've done for now I'll let you know if anything changes over the day and if that doesn't work I'll click on the advertising here and go look at something interesting and see if that causes a change. Because once we figure out our advertising choices clicking on the advertising is somehow good for the message board and we might as well look at something interesting. As opposed to trying to find the messages buried amongst all the other stuff like watches it gets confusing.
  • Haha 2
It just dawned on me that now my lathe is arriving I am going to need a new micrometer or two, mine are precision ones but for much larger items. I have no idea what size I should be looking at - I'm going to be turning balance shafts and the like, any pointers or suggestions welcome.
Despite the other day having an overwhelming desire to purchase women's underwear on eBay or at least look at it that has not translated into something apparently I need to purchase on this discussion group how sad.
EBay must be feeling really desperate if all were seeing is eBay stuff and not even seeing necessarily the stuff I look at like for instance it looks like I'm in the need of a motorcycle at least if I believe what eBay thinks
Other than the motorcycle let's what I've been seeing on the top of the page all this week with no change at all.
Oh and I notice the color scheme that you have quite stylish except I don't like it at all. This happened a while back with one of the software updates and snipping out an image for you if you go to the bottom of the page where it says theme you can hit the arrow and changed the light theme I find it much nicer to have a white background for the words.
unfortunately there doesn't seem to be in a way to pick our advertising choices.
    • Yes, what I wanted to say is that the cock is part of the main plate, manufactured together with it and not meant to be interchangeable. Even if the other cock gets in place, it is not sure that the balance then will stay upright. You should use the original cock when it exists and is not destroyed. The adjustment needed by bending it is not irreversible. It is minimal deforming that is needed. No tools are needed. I have pointed to all needed references here for the balance staff endshake checking and correctness confirmation. The only tool needed for the correction is You thumb. The cock must be fixed on the main plate, no need of special plate with holes and so on. If You will feel more confident, then measure with Vernier caliper the height of the top of the cock where the stones are against the main plate bottom when the shim is fitted and try to reach the same height when bending the cock (with no balance in place!!!) Caliper with screw for fixing is perfect.
    • Thanks for the reply. I polished the head of the screw using 1500 to 10000 lapping paper and a screw polisher. This is why I think the head blued and the rest of the screw didn't. Silly question, how do you polish the whole screw inc threads, if that's what it needs to blue? 100% clean, Elna red and heated ultrasonic bath + IPA rinse. Finally, there is definitely heat leak as there's about a 30c difference between the brass bed and the soldering station temp. Having said that, the bed temp was stable. I will try to search out a better brass pot, but I haven't found one yet, hence the stainless steel bowl.
    • Agreed but that's where WD40 excels, water displacement.
    • I would change the container to a thick walled brass one to start with. Looking at you screw pictures they don’t look shiny enough, really it’s best to do a black polish on them before trying. Also make sure once polished they are scrupulously clean, I dunk my experiments in acetone before bluing.   i think the thin walled stainless container to leach away the heat from the shavings, most successful bluing videos for example use thick walled brass to hold a good deep amount of shavings which acts as a better holder of heat.   Tom
    • …I guess my friend’s dad was duped…and by a Rolex dealer… …well, it’s a good fake 🤪 even the box and papers look legit…
