Platform woes
transporter
In need of a little help, I currently have a winter Haller and Hof Meier Fusee time only movement with platform escapement.
Now the platform isn’t the original, so firstly does anyone have one for sale, or a picture/measurements of an orginal.
Secondary and also a major problem is the entry pallet jewel has been replaced with a piece of steel.
I found the reason for this and it’s because the pallet jewel holder had been broken ( where the jewel sits sandwiched between the upper and lower bits the top bit had snapped and been soldered on with the new bit of steel for an entry pallet ).
The picture shows the exit pallet jewel as it shows how it is sandwiched between the jaws of the pallet.
The repair was reasonable but it lacked enough depth into the scape wheel teeth.
So next ask, does anyone know of where to get clock pallet jewels all my suppliers just sell the Brocot style and not lever type.
Any help greatly appreciated.
  • 5 weeks later...
Hi no idea really at my age to fiddly.  Ihave done the W&H. Mantle clocks but never had one of those with a platform.  The last platform clock I repaired was cobbled to gether from various platforms to get a working one.. there are many generic platforms but some require re drilling the plate, I take it you are trying to stay true to the clock.
Haller and Hof Meier made so many different movements it is probably imposable  to get  the proper replacement platform. I must say the one you are showing looks good the same colour brass as the movement and looks correct to the plate. When you have large pallet jewels that need replacing steel is normally the preferred replacement.
If this was in my workshop. I would make a new steel fitting to hold the pallets
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
